Ian DEVERELL
Hello Étienne. Did you manage to find a solution for you volume pot? I had a similar problem with my second au217. The only perfect fix would have been to find an original pot which is not easy or too costly. I ended up finding a Chinese "alps" one but the loudness tap wasn't in the right place. So I opened it up and adapted it by scraping the circuit board to cut off the loadness tap then re connected it with a blob of solder at the right place.
https://audiokarma.org/forums/index.php?posts/14270327/
Let me know if you want more details.
I could also give you the measurements on my original au317ll pot if you think that it would be useful.
Take care,
Ian
Take care,
Ian
