across the bench: an electronic menagerie of diagnostic oddities plus photos and design analysis
recorded a few test tracks to test the system playback ability as well, digital and analog work fine
still be a good idea to do a recap and maybe higher grade signal caps, if any exist.
one of the dc bus fuses has melted open over the years causing the offset issue and protect cycling
after installing a fresh fuse, should normally be 6.3a slow (seems over-sized), things seemed stable enough for higher variac output testing and taking it off the chain (dim bulb). adjusting bias on each channel, in the photo.
idle wattage after warm, up and bias set around 6mv each channel
amp plays and can thrash to some extent, that should do it for now. doing a recap looks expensive at first glance.
motorola 2.1 channel, perhaps vintage style plate amp minus preamp umbilical, exercising EL84 outputs
pwm heater control seems to be functional, just have to watch current flow and not over-voltage the heaters. pwm duty cycle under 10%.
recapping xover system (pair of panels) for hybrid electrostatic speakers, not much info about the brand floating around
Screenshot 2025-12-08 at 00-03-46 FS RTR DR-1 Dymistatic Speakers - Stereo Home Cinema Headpho...png
rtr dymistatic speakers with a 360 degree esl tweeter on top. havent bumped into any documentation yet but nothing is burned up on the xover boards nor the extra high voltage board either.
