What gear should I buy to start make some serious measurements of the amplifiers: Watt, THD+N, S/N ratio and so on. I have a laptop, I'm on the market for an oscilloscope, but what else: software/hardware ect?
Regards
Wow I actually thought it would be easyWell unfortunately that's a very broad subject and the best answer is that it depends on you and your budget. Its been covered at length in the past. I'd recommend that you go over to diyaudio and start digging in the "Equipment & Tools" forum. There's a thread there that was started with a similar theme recently, here. There have been others in the past.
I started with an old HP334, then moved up to an HP339A, added a Quantasylum QA400 then sold the HP339A and bought a pair of Amber 3501's before deciding I really needed a good automated system that would store data. Then I moved up to my current system which is an old Audio Precision System One which I'm quite happy with. Warning*** The AP stuff requires a custom interface so do a LOT of research if you're going to go that route.
Everything you'll look at will have its pluses and minuses and some of the minuses are significant so do your homework on whatever you're thinking about buying.
Stupid question... The amp works perfect but,,,,,
Some one told me that I have made a two groundloops!!
The two black metal pieces on each side of the caps. I'm told to cut this connection near the wires for the output stages??? The connection between 4/5....
I've attached the setup:
- 1/2 from bridge rectifiers
- 3 central groundpoint
- 4/5 out
Have you looked at the QuantAsylum products? I don’t have any personal experience with them but have had my eye on the QA401 for a while and they are much less money then even an old used AP.
Audio Precision had my attention, and thought it was just a simple purchase and ready to measure. I'll do as recommended and see what comes up
Thanks
The A250 is dead quiet, I cannot hear it connected to my speakers, and the torodial never makes a sound as it did before I started. After the mods it's the rest of the system that has come to my attention regarding noise. As DIY never ends??I don't think having the two ground bars or straps or whatever you want to call them in the outside pairs of caps is a good idea. I think that overall it would be better to have a solid plate that was wider and reached all of the caps ground terminals instead of having the short wires connecting the outer caps to the main ground plane. However if the amp is quiet and you're happy with it then I'd probably leave it alone.
Ok... D6 is not measuring correct. I pull it, measure.. then ok.. anyways I find a new diode, install on D6. Know it is also measuring incorrectly. Not like D3..I've got an A250 that's only playing mid/treble from right channel... Any idea what's wrong??
Everything looks good on the circuit.
My main focus was around D11/R11/C12/Q15..., But the rest is also ok.....
Thanks
actually I think you are right in your assumption. R14 did show odd figures in circuit. About 500ohms or something. When I desoldered D6 and replaced with new, R14 where as RN60's are... Spot on!Sorry I've been very preoccupied lately so I'm a bit late in responding.
D6? Hmm that's not one that generally fails. About the only way this should fail is if the resistance from the neg rail to D6 drops really low like well below 10k ohms for some reason. This could be due to a failing R14 or a solder bridge possibly bypassing R14.
