mondialfan
Well-Known Member
D6 is the voltage reference for the cascode which protects the input diff pair Q11 from full rail voltage. The 2SA798 is only rated for 50V Vceo. If D6 were beginning to fail open then that would allow the voltage to drift up from the 12V rating of the zener to as high as the full rail voltage. If the voltage as measured at the bases of Q9/10 were to go up well above 50v then damage to Q11 can be the result. Q9/10 would be okay as long as the current through them did not become excessive.
I would definitely be looking closely at the rear of the board in the general area of R14. There are several connections there that are very close and some are connected and others are not. I always highly scrutinize this area when I'm performing upgrade work, its the one area that would be easy to get a solder bridge in the wrong spot.
