Hi mondialfanIn the channel that is getting hot, let the channel heat up and then measure the Vre (bias voltage) for all 8 output transistors. In other words measure across all eight of the large output resistors in the affected channel and record the measured voltage. The easiest way to do this is to put one of your leads on the positive output binding post for that channel then touch your other probe to the top lead of each resistor.
Thank you for your help. I will measure it that way I hope it would read cause the last time I measured when it got hot I turned the music off and tested it then the DMM read 0 mv. This A250 is crazy when I measured immediately after turn on I got reading on left channel
( one probe on R25 other probe on R30 it read 3 mv now ) and on the right channel it read 0 mv. Then I played the music about 5 minutes it’s getting hot to the touch then I turned the music off then measured and got the reading on the left channel 0mv and the right channel read 16.5 mv
