KNielsen
Well-Known Member
@mondialfan is the GEN2 duallayer.. I se the emitters are placed different form the A250 circuit without the need of jumpers
Regards
Regards
You should be able to squeeze a 105mm into the original clamps. With a diameter up to 66mm if I remember correctly. It will bailey fit, so it need some "love" and a bit patients when mounting with the bigger diameter caps, but eventually sit in place.I will also search for power capacitors replacement. Quite tricky if one wants to stay with original clamps as all today same diameter and capacity caps are longer (95mm original, 105 and 120mm today’s).
Kind Regards
C7 220uf 35v:Halo,
Many thanks for the answer! Well I triple checked after soldering with very strong flashlight from few perspectives also lightning through the pcb you see the traces... but never mind that I did it only to check and I was sure what I was doing.
I know 105mm fits. There are few caps available. Nippon Chemicon are the cheapest, 3-4 others are from 1,5 to 4 times more expensive. I think any new cap will be better than old in case of these large cans. But what is your take as to the brand? For now I would stick to orginal configuration.
A quick questions. I have Black Gate N for input cap. What best do you recommend for non polar C7 220uF?
Second what bias is the proper and which sourse resistor to measure this is best?
I know the answers are somewhere in this thread and I will look for it but maybe someone can make quick answer.
Thanks!
Regards
Halo,
While waiting for my friend with scope to have some time I just fixed my Acurus myself
The problem was the cold solder joints. Both C7 had cold joints and loosen. Funny it happend in both channels at the same time. After resoldering both channels work and play music. If you remove C7 the symptoms are no bass and drive power, simply mid and highs are present. Additionally one channel that was showing 120mV dc offset had loosen joint on C15 and after resoldering that dc offset in this channel shows 1-2mV, the other channel shows 9-10mV
I did resoldering these without taking the pcb off, constructed the special long curverd soldering end.
Now I will take the pcbs off and resolder all the joints. Also as first mods will change C7 and C2 input caps. Will put Black Gate N in the input, it is just about the best electrolityc cap you can get, also I have 10uF ones. I will search my drewers for 220uF same type, maybe I also have them.
I also have to set the bias. I remember seeing somewhere in this thread the procedure, measuring dc on some source resistors but have to dig which ones (maybe quick advice here). I remember 6-8mV is the proper. I think mine shows 4mV and 5mV but not sure I’m measuring in the right place.
Kind Regards
C16/17: is this the post caps that are not attached. Also C4??? What is this
I measured the original A250 1/4watt resistor-holes at the board and applied this to the new PCB. But I might alter some of the components. It all went a bit fast when I discovered that the ratlines were ok after some trail and error with some footprints. Also the 10ohm at input GND is oversized I see.Looking good. What wattage rating are the degen resistors between the diff input transistors? They look overly large. 1/8w is all that is needed.
Regarding the parking lot before it all becomes to suspicious. They were moving from one place on DK to another, and this were just in between, and easy for both of us. The amps are ok and not stolen or anything.. he just "forgot!" to mention the burned channel![]()
Thanks! This is what I do
In some post earlier you mentioned you have some expirence with Pass amps. I have built a few of them in the past, also had some originals, I know Aleph 4, Aleph 3 and Aleph J. I still use copy of Aleph P preamp. How would you describe Acurus sound compared to Aleph? Since I own Thiel CS6 Alephs are no go, simply can’t drive them. This is why I got Acurus A250. Right now it’s stock with old capacitors. Sound very nice smooth, extended kind of dark. A lot of highs and bass, a bit recessed and not so detailed midrange. On some material it is softened and rounded too much. Piano does not sound very true, trumpet too little sharp etc.. So far I want to stay with Acurus as original as possible so I will not add capacity in PS etc, I do not want to loose resale value of it. I wonder how will it sound with fresh caps. I’m also interested in Aragon 8008BB so if I come across very nice one in top condition and resonable price I may be tempted. I also think it would be a nice project to build in similar way like KNielsen does with A250 here. I’m also temted to try Krell KSA250 but a nice example is beyond my budget at the moment. Thanks for the help!
