Halo, I’m still working on my A250 doing slow progress, I’m just gathering the last pieces of resistors to take it apart to change all resistors to Vishay RN60D, film caps to Wima MKP10, and Nichicon electrolitycs with Black Gate N on signal. The amp is playing all the time with my Thiel CS6. Thiels are very hard load. My bias is quite low around 4mV on emiters and yet in these hot days when I play loud it gets so hot that I can hardly touch it. I plan to put the pcbs apart and resolder all the resistors and capacitors at one time once I have everything.
I have a chance to get A200 in untouched condition and also A200x3. How would you describe the diffrance in A250 vs A200 sonically and as potential to mod. And also what would be the gain of buying A200x3? More place inside to maybe do a true dual mono with two transformers? Also can someone point out how exactly the Aragon 8008 differ from A200/250. There is some servo allowing skipping the input cap correct? All in all these are great amps to play with. Thanks in advance!
Will post the pictures once I make the progress with my A250.
