KNielsen
Well-Known Member
Updated the driver-transistors in the right channel today for a quick test. A topic that came up and mentioned by @mondialfan earlier, but this one is an A200 instead of A250.
-I simply cannot find my small ø3mm screws, so no heatsink attached yet.
Anyway
, the 3Vpp squarewave came out nice.
The output of the amp didn't climb, but only measured one channel, so maby a different result with two channels under load.
The temperature on the transistor was low enough for a listening-test, and it worked really well.
Thanks @mondialfan for the info.
The transistors does need heatsink when playing music. Compared to the ZTX, the TT-series does become quite hot (almost identical temp to ZTX), but with the TT speced at a working temp up to 150°c Vs 200°c on the ZTX I feel that a heatsink would be preferred in the long term.
Anyway
