dodog
Addicted Member
Great build, glad you got it working.
And a testament to Omishra and Sachin with the OPS, give it a week or two to burn in for it to sound it's best.
What did you use to make the hole for the XLR socket?
Thank you again for your support. I now have your preamp, a MM phono pre and two of your MC pres in the rotation. :yes:
I used a multi-sized step drill bit to get the correct diameter, then used a small file to round out the "notches" at the top and sides (if you look at the inside of the XLR, it's not really a cylinder but has small notches at 3,9,12 o'clock). Once I got that to fit I laid it in, marked the screw holes and drilled to the appropriate size. I'm sure there is a much easier way to do it but those were the tools I had. With these Hammond/aluminum enclosures I find it best to cover the panel with blue painters tape, mark all the drilling locations, then use a center punch to indent where to start. I usually start with my tiniest drill bit, work up 2-3 more sizes, then go to work with the stepped drill bit.
