Since you are the ADC XLM guru, would you be willing to write a simple reference post that lists the various cartridges and corresponding styli? Maybe you've done this somewhere, or perhaps there is a webpage?At the risk of geeksplaining:
Despite its confusing name, the XLM Mk II Improved is not simply an improved version of the XLM Mk II. It was introduced alongside the XLM Mk III Improved, is a cost-reduced version of it and shares a cartridge body with it, all of which means it will lose overall output level and gain a boost above about 5kHz when used in a "Mk I" body.
That's as "wrong" as it gets; the combo will still track and play records just fine, but I don't recommend it for the simple reason that I don't want anyone to come away with the impression that ADCs are bright-sounding or bass-shy. If you can deal with the lower output and boosted high treble-- a combination that might give someone not expecting it the impression of weak bass-- it's a good stylus, and let's face it: sometimes you have to go with what's available and make it work. But it's not hard to find an XLM/VLM/QLM36/QLM34 Mk III body for that stylus, so the strategy of grabbing an NOS stylus while you can, then getting the matching body later, has some merit. Go with a vendor who will believe you if an NOS stylus shows signs of age-hardening and will accept returns.. or else go with Jico, which won't be what I'd call cheap but does offer a version with a Shibata diamond (e000231).
As the owner of an XV-15 and an 888TE, I sympathize and have found workarounds that work for me and for others, though not from a single source.
bikehomero: Output varies among cartridges, but unless there's a mismatch between the cartridge body and the stylus, ADCs are not low in output, nor are they low in "hights", by which I assume you mean high frequencies or treble, so something is wrong. The stylus appears to be a genuine XLM Mk II Improved. It also appears to be installed correctly. The photo is very dark, but the cartridge body appears not to be the one that originally came with the XLM Mk II Improved (where the mounting bolts would be inserted through holes instead of slots), though that doesn't necessarily mean it's a "wrong" body electrically. If it was the "wrong" body, the high frequencies would be boosted, not reduced, although the overall output would be lower than specified. Do you have another stylus with which to compare?
RubinsteinAK: How about a summary of the XLM-era models excluding the Q/K/QLMs? An exhaustive list would be, well, exhausting, and since ADC didn't label their bodies with model numbers, you'd still need to measure with at least an ohmmeter and preferably an inexpensive inductance meter (<$20, eBay) to determine which of the four distinct bodies you have before you could choose a "correct" stylus. By the way, this is true of other makes of cartridges as well. Empire and even Shure come to mind.
All ohmmeter readings should be considered targets, but actual readings can be plus or minus 10%, and channels don't have to match. Keep in mind that resistance (not to be confused with impedance) measurements are only a strong clue to the inductance, which is the important parameter.
"Mk I" (XLM, VLM) : 350 ohms. ADC didn't call any model a "Mk I", but we guru types (or us guru types) do. This is analogous to what linguists call back-formation.
Mk II (not Improved) (XLM, VLM): 625 ohms. Can be considered interchangeable with "Mk I"-- the resistance figures between I and II are very different, but the inductances are very close.
Integra (XLM, XT): 760 ohms This includes the 114-DET we've recommended for your XLM Mk II Improved. Works for both Mk II and Mk III styli. Integra styli don't have Mk designations, though they were introduced along with, and use the same tech goodies as, the Mk III Improveds.
Mk II Improved and Mk III and Mk III Improved: (XLM, VLM, ZLM, Astrion): 820 ohms. ZLMs and Astrions came late in the game, so there are no Mk designations for them. There's a ZLM Select and a ZLM Improved but not an Astrion Improved. There is no VLM Mk II Improved.
As mentioned, the XLM Mk II Improved is really a Mk III and came with a Mk III body with bolt holes instead of bolt slots. The Super XLM Mk II is also really a Mk III, but came with a Mk II body, and... oh, just don't ask. Great stylus, but it needs an understanding owner.
TRX and PSX models were made after ADC stopped making their own cartridges and styli. A Japanese firm called Azden made them, and they're excellent, but not designed by Peter Pritchard, though they partake of his ideas.
Does that help at all?
I'm not bikehomero, but that info is very useful to me (see my post above). Let's say the cantilever is not properly seated in the grommet: is it safe to pull the cantilever out and reseat it correctly? Thanks for your expertise.bikehomero: It might be that the cantilever has been pushed partially out of the suspension grommet. Something which is shockingly easy to do if care isn't exercised when installing the stylus onto the cartridge body. The cantilever is held in position by flat spots machined into it in a square pattern which sort of snap into the grommet as the cantilever is inserted, holding it in the correct fore and aft position and azimuth. When properly positioned, the rear of the cantilever should protrude slightly, something on the order of 0,5 mm, from the rear of the grommet. If the rear of the cantilever is pushed forward into the grommet, it will reduce output and conceivably impair treble.
John
bikehomero: The photo is very dark, but the cartridge body appears not to be the one that originally came with the XLM Mk II Improved (where the mounting bolts would be inserted through holes instead of slots), though that doesn't necessarily mean it's a "wrong" body electrically. If it was the "wrong" body, the high frequencies would be boosted, not reduced, although the overall output would be lower than specified. Do you have another stylus with which to compare?
John
You're welcome. I'm sorry we couldn't put all your doubts to rest.Thank you for all the informations!
So have I, especially on sites like eBay, but 40 years after they were made, you have no assurance that the body + stylus presented to you came from the factory together. Fortunately for XLM Mk II Improved owners and others, there are exceptions: we have ADC's word for it that the Mk II Improved originally came with a "holes" body.I've seen both, holes and slots, together with XLM II improved bodies [I think you meant "styli"].
