mcaddie7
Hi all,
Title says it all. Found an old Zenith radio that looks pretty good. Replaced the caps and it’s singing!
However I have three issues:
1) The FM, AM, FM AmC switch is kinda bad. Any tips on replacing, / could I wire it just to FM?
2) I’d like to add a led to the tuning dial that follows the dial. Could I tap into something and scale down the voltage with a resistor?
3) if possible, could I also add an aux that takes priority? Meaning that the FM /AM plays but if something is plugged into the aux, it uses that?
Thanks!
Thanks!
