Adjusting Tonearm Height
On-the-fly tonearm height adjustment offered by a few arms can allow sonically dialing in the best sound. Whether that exactly matches the 92 degrees or whatever number is the hippest today, I don’t care cause the better sound wins that contest every time. Well except against those that need actual test results.
they make a number of different clear plastic devices that allow you to visualize the tracking angle maybe one of these would be something you would be interested in getting. I had one here but it was a bit difficult to use needing the camera to magnify and since I have adjustable on the fly vertical tracking angle, I didn’t need to have the plastic gauge.
Yes, adjustable micrometer VTA is definitely the way to go. Can really fine tine cartridge. So glad I bought one for my Jelco tonearm.
I have always thought all this tail up, tail down and more treble, more bass, stuff is pretty much nonsense. Unless the angles are extreme, the frequency response of the cartridge/stylus doesn't change that much. I have always just set the cartridge so its mounting surface is parallel to the record surface and not fret about it.
Doug
Hello,
I have two turntables and both have tonearms that sit slightly higher at the back. One is the Marantz 6200 and the other is the Technics SL-1400 Mk1. Does anyone know how to adjust the tonearm height on these turntables? I have the service manual for the Marantz 6200 but the instructions are vague and the reference picture does not make sense to me. FOr the SL-1400, I have no clue. Searched the web and the forums but no luck.View attachment 3076741View attachment 3076742
If someone can help guide, I'd appreciate it.
The following pic is of the Ortofon 2M Blue on the Technics SL-1400. Seems that the rake angle is less than 90 degrees on it. Sounds great as it is, but I am wondering if this is going to cause undue wear and if the sound cna be ev en better by making a change to the VTA and the SRA in any way.
Thanks.
If you can't adjust the arm's height, could you shim the rear of the cart itself to get the VTA in spec? That has worked on a TT I once had.
