As per the L1290 manual, recommended "minimum amplification is 15 watts per channel(30 watts or more, peak) can produce average music levels of 90db..."Was thinking of spending around 1000 to 1500...how much power would you recommend?
Maybe, maybe not. Regardless of brand, they all need or will need some kind of work at some point.Is it worth the extra money to buy a vintage McIntosh amp?
Right now I have a Yamaha Rx v630 receiver and am powering my l1290 speakers with a Parasound 75 watt per channel amp...was thinking of getting a more powerful power amp for better sound
I drove L1290s with a 140WPC B&K and is sounded fine. When I moved to a 200WPC Acurus amp, the improved depth and control of the bass was was very noticeable. Since I don't listen at ear-popping levels, I have to assume it was increased current that made the improvements in the bass. If you're looking new, you might check out the Emotivas in that price range; if used, there's a huge range of options. An Aragon 8008 or Threshold S/300 would do quite nicely if you can find one in your budget.Right now I have a Yamaha Rx v630 receiver and am powering my l1290 speakers with a Parasound 75 watt per channel amp...was thinking of getting a more powerful power amp for better sound
I've run a 2255 on my 1530's for 3 years now and I've never had the urge to try anything else other than a very brief stint with a tube amp.Thanks...I have decided to up my budget and am going with a McIntosh mc2255 with 250 watts per channel...gonna also get a Mac preamp
