soundmotor
super modified
I have no photos.
I replaced the capacitors with the same value as found on the crossover. (I do not recall what the value was.) I do not think it wise to change values from what was original. The crossover could change values in different editions and I do not consider myself smarter than the people that designed the speaker.
IIRC the original through CC versions are the same except for the treble pad resistors (IIRC). The L300e network is quite different as all the drivers were changed.
The L300 C is an early 80s variant and denotes it being for CAR use. The 206-0101A tweeter has inside dome coating vs. outside as on the no suffix L300. It may also have ferrofluid too. If so, the speaker nearing 40YO and both the FF & electrolytics are likely at the edge of service life. The tweeter caps are mylar & probably fine. If they do get swapped be aware that polypropylene ones will have a lower ESR so you might need to add resistance to the treble pads to rebalance them. It won't be much though, perhaps a few tenths ohm per side.
