Air Guns
I put this together out of the buy/sell on the Yellow Forum several years ago. It has a basic Bestune with the oem spring and Russ' trigger mod, the scope is a Maccari 4X. Sadly, it hasn't seen much use since I put it together due to shoulder injuries and concurrent lack of motivation, possibly also medically related.
I still like having it around.
Let me suggest the Hammerli 850. A CO2 rifle at 750 fps, a bolt action repeater, no recoil and accuracy in spades. An add-on muzzle brake option that when used with some Scotch 33 electrical tape becomes one of the quietest air guns around.
Just an option...
Cheers
I'm no photographer, but here's my two air rifles.
I had a Hammerli for a while, but it had a terrible, non-adjustable trigger. It was beautiful and had great accuracy potential, but the trigger was inconsistent from shot to shot, so away it went.
I had me a retired guy fun day and took the first step. I’ve had this rusty old Crosman 150 CO2 gun for 5 years just forgotten in a box. BTW I have zero Airgun experience as Dad insisted that I used .22 CB Caps for rodent control. Wagered $70 on parts, pellets and cartridges. Today I cleaned it up, rebuilt the valve and gave it a go. It’s a sweet heart even with heavy ammo to quiet it a little according to the Mac1 guy. This one was made about when I was. No plastic except the grips.
index.php
index.php
index.php
At 7 yds - the 1/2” and 9/16” groups are with it clamped in vice. Fun stuff. The bug as bitten me. Time to research optics options.
index.php
Edit: This didn’t post day before yesterday. Based on the initial success yesterday I went through the action. I flattened and polished the sear and trigger contact areas. I should have some time to try it today.
index.php
index.php
index.php
index.php
You would have to fab up a mount, but the little red-dot sights are all the rage with the target shooters (bulls-eye shooters, the tactical guys got it long ago).
Considering some of them are stuffed shirts, I'm surprised they let them be legal. Maybe the fact they are mostly old curmudgeons that can't see the sights any longer may have something to do with it. Present company included...I can't see ****.
Mac1 has a nice 1 piece rail barrel mount for a reasonable price so I’ll probably get that.
So, how much fun can you have for $30?
the Beeman P17 is an absolute hoot. I have shot around 750 pellets through it. In the last week, I've unleashed holy terror on an empty pellet tin, at 40', and it looks closer to a wadded up piece of foil than it does a pellet tin.
Alas,... I was losing pressure.
If I didn't shoot it immediately after loading it, pressure dropped, to a point where about 2 minutes later, it would not clear a pellet.
I studied a couple of YouTube vids in regard to the trigger mechanism, and, internal components, and, I tore it down last night. This morning, off to Napa Auto, and their wonderful box of o-rings,.... o-rings ain't cheap (at least compared to a $30 plinker). I broke the bank with a $2.50 repair.
So, I swapped out o-rings, and, "polished" the valve o-ring seat with a faux steel wool scour pad. I found a bit of hard to remove something there on the valve seat, and, was able to buff it out with the scouring pad.
And we're back to full pressure, and, with presure holding (passsed the half hour test). I suspect it was the deformation on the valve seat.
I've been using Crosman Premiere Hollow-Points, as they are easy to load (wadcutters are a pita), cheap at ~$5 for 500, and accurate.
The frame on the 150 is too small for my large hands so the corner digs into my thumb base joint. So I started making my 1st grip. The junk of wood is from the base of an Italian Cypress I cut down 15 years ago. I figured it should have some nice grain and it’s free if I screw it up.
E702C2F1-B9A5-4218-AB9D-844F56922F10.jpeg 80063741-186C-4107-82CD-EA4A9D43B9A4.jpeg 4A31C10B-7D03-4AD9-9EFB-031635FCB73C.jpeg A20B6C56-52C2-4E3A-BF88-8D9BC2502CF7.jpeg 6BE29A93-BAD6-4673-B4AC-75B7473BDBB3.jpeg
Here's a picture of my custom 2240 with walnut checkered grips. I haven't pick out a color of stain for the grips yet. I'm thinking red mahogany.View attachment 1626107
That looks great Bob. I see you have the wide brass trigger. I’m thinking that may be next if it’ll work on a 150. I shaved some washers down and centered the sear, but the trigger is still pushed to one side with a spring. I wanted to get it comfortable before putting the time into a new trigger. Mission accomplished. The shaping is done and it fits my hand really well.
I tried it out today. Here’s (5) 10 shot groups from 7 yards. I’m thinking a red dot sight or scope won’t be too far off now.
The grips look awesome. My custom 2240 has a lot of work that I have done to it. All the go fast goodies in it from Magnum Airpower plus I have a LW barrel on it and some stainless bling. I also have a all stock 2240. I will post some pictures of my trigger setup so you can see if it will work on the 150.
The grip frame is the only thing that is stock on my custom 2240. Everything else is a custom after market part. You can see my trigger assembly is all custom. Brass trigger that's been designed for less pull with a thicker stainless sear and pivots on new stainless pins. It also has a lighter spring that sits on an adjustable brass base. The trigger only moves about a 1/16 with about 4oz trigger pull. It also has a custom left handed stainless safety. :naughty:IMG_0869.JPG
The grip frame is the only thing that is stock on my custom 2240. Everything else is a custom after market part. You can see my trigger assembly is all custom. Brass trigger that's been designed for less pull with a thicker stainless sear and pivots on new stainless pins. It also has a lighter spring that sits on an adjustable brass base. The trigger only moves about a 1/16 with about 4oz trigger pull. It also has a custom left handed stainless safety. :naughty:View attachment 1626412
Those parts look similar, but it’s hard to tell if they ‘ll work. The 150 doesn’t have a cover plate for access. The trigger and sear have to be dropped into a slot in the frame and then pinned in place. Maneuvering the stock trigger into place was a bit tricky as it was. It’s definitely worthy of further study.
Looking closer at your pictures I did see that there's no cover plate. That's to bad. The 150 frame looks very close to the 2240 frame. I wonder if the 2240 frame will fit the 150?
are those BB shooters, or, pellet capable?
.22 cal pellet
My buddy brought over his MAC1 carbine today to start on new curly maple grips and fore end. It’s the air version of 2240. I took the frame off to trace a pattern. Had it in my hand 2 feet away on the bench and didn’t stop to try it. Damn! I’ll try it next time we get together.
I went out to walmart this morning and bought a Daisy 340 pistol.
$13.29 for the gun and 1500 BBs. I know its just a toy but here's the reason.
My wife keeps a dish of food for her male cat Peanut in her home office.
lately we noticed him going through a lot of food. last night she saw some crumbs
in front of a dresser she has in there. she pulled out the bottom drawer and found
around 7lbs of cat food stashed under the drawer in the base of the dresser and
a mouse looking at her. my only option was my Benjamin 342 .22 rifle , a bit
overkill for a mouse. this pistol should do the trick next time. with 3 cats we do
see a mouse now and then but they always find a place where the cats can't reach them.
pictured is a 5 shot group from 10 feet. at 240 fps it should take care of a mouse.
