It is a fun shot, but a total challenge.
The pellet is hit with immediate cross-wind, and requires a windage off-set, unless it is totally still. But, when it is totally still, it is even harder to make the shot. Huh?!?
OK,... I've mentioned that I can see pellets in flight. WIth this shot, and, when it is windy, i can see what is best described as the pellet coming in like a "slider" pitch; sort of a curving horizontal trajectory. The pellet meets imediate wind, and is blown sideways. The windage offset corrects that, but, is then quite quickly neutraized by the trees that I'm trying to go under.
There is something about the windage offset, and that slider effect that curves the pellet in closer to that metal framework. I've made shots that I'd never conceive of having hit in there, that I had no business being able to hit, except for that slider pitch.
Beeman QB Chief 1322
Scoped?... Yes.
UTG Leapers 4-16x44 Mini-Swat AO scope, with a side AO wheel (coolest thing ever!)
Scope mounting base:
Dovetail-to-Picatinny rail adaptor, with a forward canting of 10" @ 100yards (fancy words for, the mount is sloped forward, high to the rear)
The canted base was necessary as the rifle seemed to get stuck far below target while trying to sight it in to zero. In fact, the scope was at the extreme stopped end of upward adjustment, which made it extremely unstable. I'd get it sighted, and then set the rifle down to pump it back up, and the scope would completely scramble; as if I'd not done any adjustments at all.
I asked a question to Tom Gaylord, air gun guru, and as Pyramid Air contributor BB Pelletier, and he suggested the fact that the scope was stressed beyond capability, and that I needed to find a forward canted mount that are usually meant for break barrel rifles with sagging barrels. So, I search, and found the UTG 10" forward canting mount, and bought it. Voila! A miracle occurred, and, the scope stabilized, completely. The canted mount allowed me to bring everything back to a better
middlin setting, which the scope liked.
What really impreswed me about Tom Gaylord is, that the mount that solved my problem was one that he designed, but, was too humble to outright boast about, or push. It wasn't until after I made the purchase that he told me that it was his design.
The sidewheel AO adjustement is really cool. But, what is the best is the resettable windage and elevation turrets! Those make repeatable shots a dream.
View attachment 1635885 View attachment 1635886
