I regret to inform the world, but, there is one less Sage Rat in the population this afternoon.
they're becoming scarce in my immediate vicinity.
So, I got bored probably last friday, or so. I decided to watch a couple of videos on the Beeman QB triggers, and how they adjust. They're said to have a very finely adjustable trigger, with three possible adjustments.
Me: this has high potential for me shooting myself, or something stupid like that; and this is what has taken me so long to do this....
So, I took the stock off (after removing the safety switch), and, exposed the trigger housing. I opened it up, and had a look inside.
You see a spring to the left of the trigger, and two screws above that.
The top screw limits the amount of sear contact that is made.
The midddle screw is a stop, preventing travel beyond a set point.
The spring is how much load/weight it takes to activate the firing.
To prevent being the idiot that shoots himself, I opted for full sear contact, so that it wouldn't go off when setting it down. To make sure of this, I bounced it pretty hard on the butt a few times.
I adjusted the trigger to a far finer/softer pull. This softer pull was extremely helpful in preventing what was an occasional over-excited trigger pull, that pulled the shot left.
Then, it took until this afternoon, when I saw a similar silhouette out at 250'. I made an elevation adjustment of +10, which I know works; adjusted 4/8 windage, to the right, to compensate for the howling Santa Ana winds of the day, and, lightly tickled the trigger, and, saw the pellet hit just behnd the head, into the upper torso; damn, I needed a 5/8right windage offset for the headshot.
Result: Another tasty Coyote slider.
The trigger pull is longer than it was before I messed with it, which is fine. The softer pull is a total bonus for watching this all play out through the scope.
