Air Guns
How long would it take to fill a standard scuba tank with one of those?
I haven't filled scuba tanks with it so I can't say. But I have seen other people filling 88cf tanks in 20 to 30 minutes. When I first got it now that I think about i did fill a tank for a friend that I think it was a 74cf to see how it worked. From empty to 3,000 psi took about 1 hour but that was shutting it down to cool also.The air that comes out of these are not made for breathing just for air guns. ;)
been looking at that yong heng and just wondering how well it stood up, thanks
I have had this for about 7or 8 months and it still works fine. But I just fill my air guns with it not tanks so it doesn't run to long. The main thing is to keep them cool running and change the oil all the time. You can see in my picture I have a 14gallon bucket of distilled water with 2 bottles of water wetter added. My pump doesn't run that hot the way it's setup but I will shut it off if it reaches 150f. Hi heat will kill them quick.
There cheap china compressor for about $230. So I would want to fill tanks with them all the time.
Consider that when using a scuba or other tank to fill your guns, you only do a total fill of the tank when it's new, and after inspection/testing. Otherwise, you'll only run the tank down to the lowest minimum fill pressure of the gun's you're supplying.
One of my un-regulated PCP's only get's filled to the top of it's sweet spot which is about 2650 psi. So, unless somebody's been messin' with it, my 80 ft3 scuba tank never goes below that pressure.
Another little secret, join your local volunteer fire department. Donating some of your time and effort can earn you the perk of free 4500 psi fills, and at the same time you get to feel good about helping others. There's no safer way to fill bottles than in an OSHA approved cascade system.
All that said, i still do plenty of hand pumping out in the field. To me, it's much akin to the sport in drawing a bow, kind of a purist thing.
Sage advice Mr. BT427SS. I totally get what you what you are saying. Keep the tank above the PCPs max, or close thereto, otherwise you end up with a partially filled PCP.
Any one use air guns here? Not air soft toys, but pellet guns, for hunting. I sold all my fire arms and concentrate on air guns now. I don't have one that will do big game yet ( they do make them in up to .50 caliber that will take dear, hogs and other larger game animals). Mine is a custom carbine style. Just wondering.
I love airguns. Currently I own:
Winchester 722X .22 cal. break barrel rifle
Crosman F4 model CFTNP17 nitro piston .177 break barrel rifle
Crosman 1077 .177 CO2 semi-auto rifle
Red Ryder .177 BB repeater rifle
Vintage Crosman 150 second series with 3 step hammer(made in Fairport, NY) .22 cal. CO2 PELLGUN
Vintage Marksman(made in Torrance California) .177 BB repeater. Also shoots pellets.
Newer style Marksman(Huntington Beach, CA) .177 BB repeater. Also shoots pellets.
I have an old Crossman Mark 2 CO2 pistol that won't hold pressure- should I look into converting to a paintball bottle? Is that possible?
The new Pyramid Air catalog arrived today. Always a fun read. Some really interesting articles; of special interest to me is an article on how rifling traces are applied to the barrel. I knew nothing about it going in; something learned.
Two new PCP toys from Beeman
Chief II
2k psi reservoir
bolt action - rotary clip (Chief v.1 is a single shot - still available)
$199 at PA
Commander
3k PSI air reservoir
$219 at PA
This one looks a bit like some of the Diana line, ^
The Chief v.1 single shot is $179, same as last year.
That’s what I did with my 150. Then I deburred, polished and shimmed the trigger and sear. After that I made grips. There’s some pics posted in this thread. Next is a red dot site as the sights are terrible.
A .22 with a headshot would work. Or more efficiently, a .25, but pellets and the guns are not so common brick and mortar type availability.
How well can you see them? I'm assuming these are a nighttime issue for you??
(_8^(|) .... d'oh!
I blew the shot of a lifetime today. Yep, thats how much I suck!
OK,... this is from my second longest shot, out apprx. 250' or so, and 20' lower than I am at that range; and, this one that has been dead for most of the year.
I keep an eye on it, hoping, but, noting, nothing,.... until this morning, when a Sage Rat emerges from the shrubline. I pretty much bolt back to the house for the shooting stick. I race back out, but, it was gone. So, I set up camp, and wait. Nothing... nothing,.... n o t h i n g,...... taps fingers,...
This played out for stupidly long (20min or so), and I opted to move to my more southern outpost, that provides a different view of this same spot. I get there, and, what emerges from the same bushes, as viewed from the place I just left?? you got it, the Sage Rat.
So, I head back to the Western Outpost, and have a look, and its still there. So, I take aim, focus, adjust elevation to 12/16, find my spot, and am starting to pull the trigger,..... and,.... what happens next?
A second Sage Rat emerges, and runs to the first one, and they start into smelling each other, or something; two squirrels, parallel to each other, with their heads immediately next to each other, creating one long length of rodent,... and I'm dialed in.
I pull the trigger, and,.... I friggen give them both a matching diagonal reverse Mohawk across the tops of their noggins, and splash dirt just beyond them. Off to the shrubs they ran.
I suck!!
(_8^(|) .... d'oh!
I suck!!
Head shots at 80+ yards, with an air rifle, I would say you far from suck...
Can you explain this? "...adjust elevation to 12/16" I don't understand to what this refers. Hold over, or Kentucky windage of some kind I assume.
@Ross6860
I have a UTG Leapers Accushot scope. One of its nice features are resettable adjustment turrets. This essentially means, that after you zero the scope, you loosen the turrets caps, and, reset them to "0" on both windage and elevation.
On this scope, there are whole even numbers highlighted, with smaller hash marks between whole numbers. On the windage turret, you can adjust right or left advantage between 0 -> 8, both directions.
On the elevation turret, you can adjust from 0 -> *18 as a full 360º rotation of the turret.
I set my zero in my backyard at around 80', because it has a nice, safe, firewood backdrop there (and I shoot into a pellet trap).
My entire rear of property is covered at that "0" setting.
I live in the top end of a tributary canyon, and am on an east slope, leading towards a north/south "stream" bottom at around 215', and, then it rises back up onto a western side slope. When I go out front to my active blinds, I know exactly what that "0" is capabale of in an area of view that is likely 75º wide, and ranges from a drop of a minimum of 6' instantly, and out to a drop of 20' at 215' distance.
At 300'. I'm shooting dead level across this little canyon dell, at 215' I'm still shooting down. At the bottom of the creek, I'm shooting at "0", but as soon as it rises up, I need to start compensating, and I've learned and logged those elevation change points. So, this shot was up 12 of a possible 18, of a full rotation at 250'. At 300' across canyon, level to my position, I'm at *18/18
*18 does not register as such. At that full rotation, 18 and 0 become the same number, leading to possible confusion. That is why I do not go beyond the single full rotation on either turret.
I don't like to go beyond that single rotation of the turrets, as I'm very likely to forget, and make a wrong adjustment to get back to "0" (and have). So, I keep the turret adjustments at or below their single rotation. Beyond that, I start holding over with the MilDots.
