@elcoholic
That was the other part of the inspiration; your friends version.
I started researching it, and found the Pyramid Air version, and the main source of them, the Crosman Custom shop. And, I'll see if it needs to be shooshed, and deal with that, at that point [smilie here]
The saga of the Beeman Chief continues. I'm getting to learn it, and, love it that much more, despite all of the isms that I report.
I'd suggested taking the barrel out, and, taking a Dremel and tapered grinder to the breech/barrel interface.
Well, this was a fantastic positive move. And accuracy was a total bonus.
I suggest what was happening is that in the barrel design, the air entry port is a simple hole through the bottom of the barrel, perpendicular, up into the same breech interface that Im dealing with. That air port hole through the barrel is supported below by a tall sided "o-ring" that fits between the valve and the barrel, as well as a trio of o-rings within the breech block barrel surround interface, that keep the air pressure focused
From what I've learned of it, the seals all do a good job. It is the entry port, being perpendicular to the barrel loading direction, that has been where the issue arose. That port was scoring the sides of the pellets at the skirt, perhaps with a raised burr? It also seems that some pellets wanted to do a nose dip into the hole, also introducing some distortions. This was especially prevalent with the jumbo heavy pellets.
So, I took the Dremel, and rechucked a smaller, finer, tapered grinder bit, and I lapped the entire area, creating more of a polish, and recessing that area of that hole. I did this, again, not as a rotary tool, but more like a file, in and out.
In order to compensate for the grinding, I looked at the bolt pellet probe, and its o-rings and tested that area for seal. I put a small dried-out leaf on top of the bolt, and fired it. The leaf took off like a rocket; bad o-rings. Imagine, after only firing like 6k pellets, they'd worn out??
So, I looked at the barrel o-rings, also worn from removing the barrel numerous times,....
I decide to dive into the bolt mechanism, and remove it. This is a fairly deep dive. This requires the breech to be removed, the rear of the air reservoir chamber opened, and trigger mechanism to be removed,... lots of screws, and opportunites to really mess it up.
Bolt removed, and tiny o-rings taken off, all while managing to spear my finger ony once with the sharp pick that I was using; deep, bled a lot, left pointer finger, tip.
So, off to the Napa Auto box of o-rings. Problem: They didn't have any as small as the pellet probe o-rings. So, off to the Joes Hardware and its nightmare of drawers full of o-rings.
He strikes out again,...., except for the 250count box of assorted metric o-rings, which had the right size, of which I needed only one. So, I'm buying the metric assortment, why not the SAE kit as well?
So, I now have 499 o-rings more than I needed. I should be able to accomplish the task.
I get home, and, find that the o-ring assortment size provided me with a tapered seal that perfectly fits my now slightly reshaped probe seat. I tried a similar leaf laid over the bolt, and fired, and, no motion, breech sealed.
The pellets now drop into the breech without any incidental contact (before it felt like one or two clicks that reshaped the skirt as I closed the bolt). I don't have any heavyweight pellets, and my largest is the Ruger Superpoints 17grain. But they've really changed their performance now, whereas, they were mostly good, but occasionally ended up with flyers; yesterdays plinking really impressed me for what a difference all the tinkering made. I was whacking the tiniest spots at 200', picking petals off of fallen bouganvilla flowers, splitting leaves, and, for fun, trimming a tall weed called Indian Tobacco to the ground, picking off one stem at a time.
I took this fun, and focused it towards a hanging grapefruit at 200'. I center punched it a couple of times to get ranged, and then decided to try to hit the stem, and pick it from the tree. That took me four shots to accomplish. The first two hit to the right, at the very top apex of the grapefruit, ripping slight "U-shaped" channels across the top of the rind no more than a half inch right. This was at my windage zero setting. So, I then adjusted windage one value left, and fired, and, left a similar channeled trace to the left of the stem by the slightest fraction. So, I readjusted back to zero, and waited for no wind, and, the fourth shot cleanly parted the stem.
So, the tune-up session was very beneficial. Another day, another tweak.
