Air Guns
And, just like that, a perforated Sage Rat is added to the mix. A two'fer day.
Basically the same shot as above, but, a bit shorter, at the sun ray, near the shrub at the top right corner in the image above; likely 225'; at the hard right of the clearing at the weed/shrub edge, where the sun ray meets it. It made it back into an insanely thick shrubline, filled with burrows, and, into a tunnel.
At any rate, two extremely destructive tunneling pests removed.
@Jeffery
Sarge and I have been really enjoying this one. I turned her onto blasting full hard-shaken Club Soda cans. The first time she popped one, her jaw dropped, and, we made sure that we had a 12pack of them in the cart at our next trip to town grocery gettin'. They explode all over the place, and don't leave any residue for the ants and other critters to swarm onto.
I have a 1377 that I finally got dialed in just right and now it's quit pressuring up. I took the pumping mechanism apart, it looked fine. I didn't try to get into the valve part, I know special tools are required on some of the rifles and I didn't want to risk messing anything up.
It's scheduled for delivery tomorrow, I'll post a pic if it makes it (Fedex w/signature, I hope it's tomorrow). I had Pyramid install the breech, $25 and it'll be right.
IMG_0971.JPG It holds 1 in the chamber 9 in the mag. Comes with two clips for different size pellets. Works great. IMG_0973.JPG
@bob06 So, do you fit a scope over the top, assuming?
Opinions sought, after revealing my sinister master plan.
Damn, the sight that came with the 1322 is plainly just nothing shy of a total POS. But for the moment it is what it is, and what I have.
It blows my mind that Crosman thought that a tiny self tapping elevation screw, screwed into plastic, would be worth putting on!? That little screw came to me already stripped. Elevation has been all over the place. So I rezero, and, shortly after, we're back to who knows where?
I tried a drip of JB Weld into the hole; bupkis. So, I took the thing off, removed the elevation screw, and went to Joes Hardware hardware room this morning. Yikes.
I found that a #2 machine screw fit the slot in the peep/notch blade just fine; perfectly. So, i bought two setups of screw/nut/washer, as I expected to lose one of them in the process, as they're so tiny.
I had to grind the screw to length, as it was in between sizes, and needed to fit perfectly, along side the far larger screw that holds the rear of the breech to the pressure tube and trigger housing, both within that same hole.
This all took the better part of a couple of hours. But, I won, and that new elevation machine screw, and nut, are in place.
to the sinister part,....
Sarge noticed all of this, and mentioned that it might be better to get the steel breech. [according to plan evil wink simile here]
to the opinions sought part,...
Steel?, or, something like this, of aluminum?
https://www.bakerairguns.com/product/aluminum-anodized-black-receivers/
My thought on the Al. model, is they claim half the weight of the steel breech, and, Sarge loves how light this thing is. So weight does come into consideration.
The fix the stupid stripped elevation screw mod:
The slotted machine screw, and its no clearajce fit with the main breech screw
doubled jam-nutted sight blade side.
The front optical sight requires that the rear sight be elevated high enough that it exposes a gap in the adjustment slot just below the peep hole, which looks like a second, lower peep hole. So, some flat black stage tape was applied to the sight, just above the jam nuts.
Sarge loves the Peep sight!
Me: I can't see what happens after the shot, which is absolutely crucial to my learning.
Nothing wrong with saving weight. The aluminum one will work. :thumbsup:
About 30' away. Good for up to 100yrds. Gets on target quick. ;)IMG_0993.JPG
@bob06
How about in daylight?
Me: I suck.
I missed another headshot by an inch due to incorrect windage out around the 250' mark. I guessed zero offset, and fired,... just as a gust came through. I splashed dirt in front of it; dead on for elevation, but just about an inch too far right due to the gust.
It was just a foot or so from where I pegged the gopher at long distance last week. I've taken this shot a bazillion times, and know the exact elevation increase needed; but the windage is always the wildcard.
I owned a lot of them a couple years ago.
Daystate Wolverine .308 200++Joules , Drummen Sinner custom made in the Netherlands .223 130 Joule & .308 well over 300 Joule , FX Boss .30 100+ Joule , Daystate Air Ranger .223 110 Joule , Daystate Air Ranger Tacticle .22 60 Joule , Air Arms S400 custom powertuned by a skilled gunsmith , Custom made one off Theoben MKII pistol .25 and over 55 Joule , FX Ranchero .22 pistol 30 Joule , Air Arms Pro Sport spring rifle .177 16 Joule , Air Arms S410 TDR .22 16 Joule , Diana 34 .177 , Diana 48 .177 , Diana 48 .22 , Diana 350 Magnum .22 spring rifle 35 Joule , Diana LP8 spring pistol .177 7.5 Joule , Webley Patriot .22 spring rifle , Webley Hurricane .177 spring pistol , both Webley’s from the United Kingdom.
I did some competition shooting in the Netherlands with the FX Boss , Wolverine and Drummen Sinner. Distance 100 Meter , 108 Yards. My best group ever was 11,9mm 5 shots on 100 Meter. Thats 0.47 inch at 108 Yards
FX Boss with Zeiss Victory Diavary 6-24x56
Theoben Pistol custom made (one in the world) Me shooting at 108 Yards
This pistol shoots trough a thick alluminum backing pan at 25 Yards. I often used them as a gong at 108 Yards as shown in this video. At 108 Yards it makes big deep dents in the pan. Out of 12 shots i could hit the pan consistantly about 8-9 times at that distance.
My dad shooting the Sinner .223 at 108 Yards
it shoots 41.5 Grain .223 bullets with 311 Meter per Second (1020fps) The Sinner in .223 & .308 and The Daystate Wolverine with custom Lothar Walther .308 barrel shoots clean trough a aluminum baking pan and also trough a steel baking pan at 108 Yards. These have some serious power.
Practice shooting results with the Sinner on 108 Yards
(this was the first time i shot the Sinner with brand new Lothar Walther .223 barrel) before i used the .308 barrel but the .223 was way more accurate.
This was not my Sinner but i was test shooting it. It had a new 9mm barrel and had a powertune. I was sighting in a new scope. This beast has well over 600 Joules. More than a Glock 9mm fire arm. It gave a nice kick in the shoulder and sounded absolute badass in the underground range. Listen this on a stereo and cranck the volume up. Its insane :) You can test you’re subwoofer with this XD
https://youtu.be/BGsNM7I_CMk
Daystate Wolverine .308 , me shooting at 108 yards
https://youtu.be/jvu7M-drZ3E
Pretty accurate .308 hollow points. This is the nicest air rifle ever made in my opinion. For shure the nicest i ever had.
i don’t have them anymore , after years of intensive shooting and going trough the whole country to almost every competition i lost the fun in it all.
Air rifles are way more fun than fire arms. I had a couple of fire arms also. But i got the biggest smile when i shot way tider groups at the range with my Sinner and FX Boss air rifles than shooters with some .308 fire arms rifles.
The gunsmith who makes the Sinner air rifles also makes an even more awesome air rifle. Its called the Gaint. It shoots .45 big ass solid slugs , 300 and 400 grain. Power 760 Joule. It weighs 19.5 pounds without scope. The recoil is almost comparable with a .308 fire arm.
There is a video on youtube of someone who shoots with the .223 Sinner at 500 Yards and hitting the target dead center. I always wished that i had that kind of long range places to shoot :)
(Found it)
https://youtu.be/6Dn9XHKMJsM
@bob06
Me: I suck.
It was cloudy today so it worked fine. No sun till Sunday or Monday so we'll see then. Try shooting slugs. A lot better in the wind. See the difference. IMG_0996.JPG
I need to try the slugs. I tried the one with the hour glass shape, and they were blown.
The wind isn't generally too bad, which is a problem of itself, as it is sort of hard to figure out a gust or not.
OK,... Pringles chips lids fit the larger Crosman pellet tins perfectly; and shake the tin upsidedown firm.. This is a whole lot easier to deal with than the notorious cross-threaded lids.
Plastic lid on:
off:
Plastic lid on:
off:
I thought you had a .22 cal? I never checked to see if they make .177 cal slugs. Small light pellets will differently be blown around in the wind. :whip::)
@bob06
My Beeman rifle is a .22, as well as the new Crosman Backpacker 1322
The p17 is my .177 cal. Those are the only pellet tins that the Pringles lid fit onto. I have a few of those tins, but only the one lid shown, that I retrieved in line at the grocery store yesterday, when a coustomer ahead of me opnened a snack pack, and threw the lid away. I don't do Pringles. So, I grabbed the opportunity to bag the lid when he went to throw it away.
The Sheridan air rifles used .20
cal slug-like cylindrical pellets, a reasonably potent pumper combo.
I remember reading somewhere the rational for Diablo pellets.
@bob06
I forgot about your P shooter. :rflmao:That's the only .177 cal I have also.
Haven't read the whole thread but I got to use a Gamo break-barrel with a scope on it last weekend that my friend's son bought at a pawnshop. I don't know the model but it was an impressive unit and I was doing way better (as a very infrequent/rookie shooter) hitting pop cans than I ever did with other rifles. He said this one retails for $260 something and he bought it for sixty bucks. Got half a mind to troll the pawnshops. It was some cool fun.
Edit: May have been the Gamo Whisper, I know it had some kind of silencer on it.
@toxcrusadr
Sarge had no idea about shooting at full Club Soda until just a couple of weeks ago. She loved it. Her eyes got big as plates the first time she hit one. Good fun!
