Air Guns
The present condition of my Beeman Chief.
The rodents get a free pass tomorrow, whie I get new o-rings.
It has a very slow leak. I took the parts out, and felt a little roughness at the valve and gate block (pressure gauge block). They're deep enough of a dig that it doesn't make sense to reassemble without new rings, which I do not have at hand. So, tomorrow, Ace Hardware and Napa Auto, here I come.
It all went back together well enough. I put in 8 new main o-rings in the deep works. The other ones are more external, and can be dealt with without the deep dive.
I'm in the wait and see mode, to see if it'll hold pressure.
While we're waiting for the overnight pressure check results...
this is the re-zeroing after putting the barrel back on.
The lowest holes are not flyers. I was aiming below the plate, at the backing, on center below the plate. The first three shots were the first after putting the barrel back on; those to the left, and off-center. I readjusted the barrel band, and added a touch more right, which is the fourth low shot, on center. I then took it to the plate, and,...
75' is my now longtime zero in depth, across 3/4 of the rear of the house, acros the patio. It is now fairly formulaic. I use Crosman Destroyers for the Zero, and for most plinking under a hundred feet. I've found that when I take it out front to the long shots, it translates really well to the Ruger Superpoints that I use for the longer shots. My zero holds out, out front, out to the area where the drop in elevation hits the creek bottom, and starts to rise again. From there I need to add elevation. But, with this formula for getting to zero, I've been able to stay with logs that I started now quite some time ago.
At ay rate,... 10 in a 1" diamond from 75' (two sets to the left nearly same-holed)
I then took it out to my long range shots, and, blasted a leaf out at 250'; made it disappear. And then I took aim at an old macadamia nut shell out at 225', right at the end of my true-zero, and just before the hill rises out away from me at the creek bottom.
The nut had had rain erode the dirt around it, and it sat proudly, square on top of the gopher mound..... pffft, disappeared without any dirt being disturbed. me: jaw-slacked. a good zero acheived.
/boasting
I love my Beeman, and sure hope I got the leak fixed.
OK,... I lost 1k-psi overnight. Fother Mucker!!
So, I'm not going to dig in again into the deep stuff (my thought from this morning), as those o-rings were babied into place. I made sure that the main valve/air reservoir tub was cleaned and it looked polished inside when I was done. All sharp edges were covered in blue tape to prevent rubbing. A light dab or white lithium grease on the o-rings, to make them slide into place, and, all of the valve components were replaced. The threaded components got carefully cut to size heavy duty blue teflon tape applied to the threads (despite them also being sealed with new o-rings that sealed those same threads). There is no way that this is where the leak came from last night.
My suspicions became the fill valve and the one-way fill check valve. These are the external o-rings that I mentioned.
I tried to remove the smallest of all of the o-rings yesterday, but, I couldn't get it to budge, and did not have a replacement. So, this morning, I found a replacement and degassed the air tube again (the worst part in all of this is the refilling of air). I took the check valve apart, and, looked again at the o-ring that whooped me yesterday, this fat yet tiny speck of rubber donut. I got out my o-ring pick, and tried to remove it, and thought it was stuck in an o-ring seat. Even with a scary sharp pick point, I couldn't get the o-ring to budge. So, I broke out a razor blade, and just cut the ****er, and stripped it off with pliers.
WOW! There was no o-ring seat for that little speck of rubber. This mere speck of an o-ring had borne nearly 2k.psi for nearly two year, and it had just bonded to hardened chrome steel like it was part of it.
Two new o-rings applied, and repressurized to 2k-psi, and, holding steady now for several hours. Me thinks that my problem was borne out of that tiny o-ring that had its life squeezed out of it at 2k, and it just gave up caring.
replaced, and watching.
Nice shooting @mfrench I haven't been shooting my rifles much winter is here. Just been plinking with my pistols in the basement. Can't wait for the nice weather again. I just finished hot rodding a new rifle that I'm dying to try out long range. It's the newest version of the Gamo Urban the GX-40.
I don't typically use smilies, but, in this case,...
o_O:mad::confused::crazy::thumbsdown::wtf::bs:
After like a dozen times of being broken down to its components, and, going through o-rings like so much air past a leak,.... I decided to break down to just the air tube, and pump up again to around 800lbs of pressure, I took it into a water bath tank, and watched for leaks. Oh yeah, we had leaks.
Leak point one: The forearm air pressure gauge.
I put in new rings, sealed the threads, and did everything that you can imagine to try to seal this otherwise simple feature. I could not see a leak where it connected.
It wasn't until I went into the dip bath that I saw it leaking, from the presure relief safety vent on the back side of the gauge.
Leak point two: I need a new transfer port seal. This isn't that hard of a fix. But it did obscure where I really did have a problem.
Major leak:
Beeman Chiefs seem to have a defective valve poppet design. Mine failed catastrophically at the one year warranty end mark, and Beeman replaced it; July '19
It was a classic catastrophoic failure; all air relased in one shot, because the poppet failed.
Now, it seems, 6 months later, that the new poppet has failed. But because of the hardened transfer port seal between valve and breech, air was slowly leaking out of the breech, and not through the barrel. So I missed it in that direction.
So, I tried fitting an o-ring to the poppet stem, at the valve seat interface. The o-ring solved the leak, but, caused erratic release of air, as the high pressure air tried to push it downstream. On to other theories, and tear down number 230
I took the poppet out to my drill press, and, used file to try to reshape the face, and flatten it out a bit. This worked, to a degree, but, I still had perhaps about 25% of the leak remaining.
So, I disassembled for like time #300, and looked at the poppet seat, and thought I'd try to remove that extra little bit. FOCK!! Too much, and, now the poppet wouldn't seal at all, air straight out of the barrel.
Flashback to last friday: I found a machinist who will spin me a new poppet out of whatever I want it to be of. Acetal-Delrin, per the original, or, other form. I have some plans working in my mind.
Back to the now dead valve poppet,...
I took my favorite, JB-Weld epoxy, this time the Kwik formula, and, some denatured alcohol and blue tape, and I made a well around the rim of the poppet, and I poured about 1/32" deep epoxy face on the poppet. I let it cure for several hours, and, reassembled the valve, and air tube. And,.....
wait for it....
wait for it,.....
wait for it,.....
The new epoxy poppet pressured up perfectly. I took it up to 1000 pounds, and went into the dip tank with it again, and, it held perfectly in the dip tank.
So, I cocked it, and, let a shot rip, wondering, if perhaps I might have glued the valve shut (it is JB-Weld afterall; better than duct tape and bailing wire!) But it cracked off a round, perfectly, and closed/reseated without further loss.
I've cracked off a couple of more shots since then, and back into the dip tank, and same results, pressure holding. So, I'm going to go back to 1k overnight, and, we're hoping once again for the overnight pressure check.
If it continues to leak, i have some notions for a poppet with replaceable seals on the end, machine screwed onto place, and perhaps a brass, or, aluminum poppet with a replaceable seal.
Overnight report:
We did reasonably well, considering I can't fix the gauge leak until I get a new gauge (awaiting delivery). I was going to let it sit overnight at 1k psi. But because of the gauge leak, I went to 1200psi, in hopes of waking up to 1k psi. And that is exactly where it was.
Are you in contact with the manufacturer about your findings? I would hope they would be interested and possibly consider some improvements to their products.
It would be nice if they recognized you in some way too.
Not at this point. I'm not sure how much good it would do.
I asked the tech, Peter, and, an office lady, about who I might write to in regards to what a great job that I thought that Peter had done. Both he and the secretary both suggested that the people that would matter at that level in the company didn't speak english (chinese company now). They eluded to a strong disconnect between the company in China, and their location/staff in L.A..
Peter is very knowledgeable about air guns, and design. He has a full machine shop at his disposal. He showed me his creations that he has made, noise baffles, regulators, air tank connectors, bottled air conversions, etc, and they are all top notch in design and execution. He is really sharp. And I asked him if Beeman had used any of his designs; nope. Again, a disconnect. He is a resource that they need to be tapping.
At this point, I think I'll either make it work on my own, or, move on. The works of the rifle are so simple, though, and at this point, I can work the thing blindfolded, military style. The toughest part is this poppet seal, and, with some more thought, I'm going to come up with a poppet that is bullet proof. So, I'm confident that i can make it work, and, not dog me anymore.
Beeman,... eventually, they'll catch on.
I tried writing to Beeman, merely asking if a poppet might be machined. No response, yet. I did it on a friday. I'm hoping to at least hear from them on monday.
Not wanting to just sit around for that, I continued my effort at the cheapskate fix. The machinist wanted $50 for a custom piece; more than I wanted to spend.
I've been silently wanting to kill something in trying to fix this valve. I've tried numerous ways of sealing it, with various items. Then, I hit on one that has stood up to probably 150 pop cycles now, and, is still holding strong. Its seal is very positive and natural feeling on hand pumping fills.
Its always too soon to declare victory in fixing, retrofitting, poor design. But at this point, I have very solid feelings about this one.
Since my last post, I've tried numerous way to attach a new face to the poppet, without much luck, as nothing wanted to stay in place due to the rush of outgoing pressure. So, I chucked the poppet up in my drill press, and held a razor knife as a scraping tool, and cleaned a new seat face on the poppet. I then took a nylon flat washer with an outer diameter that is just shy of the outer diameter of the poppet, and, a short piece of K&N brass precision tubing, with an inner diameter that is a natural snug-loose fit to the striker stem, a really nice fitting ring. I then embedded the whole thing monolithically into some epoxy, and then clamped it in the valve body, under spring pressure until the epoxy dried. Then I applied 1k.psi overnight.
I've disassembled the valve now a couple of times, and, it still looks like when I installed it. Everything is tight, and, in place; no gaps.
My intention with the epoxy was an embedding, and, to act as a seal around the edges of the washer, to give that hard edge a bit of rolled over aerodynamics. It also grasps the brass tubing section quite well, and is removable. I've used it in several iterations, and, it has not released. It is just the tiniest fraction larger diameter than the poppet stem, and, hardly intrudes in the air passage.
I'll keep the thread posted as this plays out. But so far, this is a .12¢ fix.
This leads me to start thinking about a better replaceable poppet face of nylon, as it has always done me very well in different pressure seal application.
Will it hold up?
Did the Beeman??
We'll see.
oh yeah, i bought a new gauge at a paintball supply store; its bad; stuck at 3k from a 2k fill. Acckk!!
At least its sealed, so I can see that there are no leaks at present!!
To sum it up...
A Beeman Chief is a bit akin to a Bic lighter. You use it up, and, know its going to have the valve fail at some point. I'm just trying to figure out how to get some gas back into it, instead of sending another one off to the landfill. These are my efforts at an inexpensive restoration.
I need to be careful with funding right now, due to some pending med. bills. So, right now, a .12¢ fix is way better than a $50 fix.
If this leaking valve can be resolved, the rest of the works are really quite simple. What you're seeing are my attempts to straighten out what I need to do if I need to take it to a pro machinist.
I'd be more comfortable with this latest iteration, if the nylon surface were thicker. But, I cannot spare anymore thickness added (learned the hard way). To do so, would require the face to be accurately machined back, and that adds expense.
So, I learn the system even more, and develop a lifetime air rifle, hopefully. It really is that simple of a system outside of this.
Yesterday was my birthday and lookie here what my wife found in my Amazon wishlist to get me for my old Crosman 150. Time to get busy and zero this thing.
Gun looks great and Happy Birthday! :beerchug:
Thanks & Thanks bob. The mount is clunky but the best I can do on the cheap. There’s little available for the early ones. Got it zeroed and killed a bunch of water bottles. I think next up will be fitting a wide trigger. Hopefully it’ll fit through the trigger guard and slot.
They make trigger shoes there called for the 2240's and other models. They just screw on to the stock trigger. Don't even have to take the gun apart. Check Ebay.
