Air Guns
I am talking about air rifles that hold a 10 pellet cartridge that appears to stick out far enough to impede the placing of the scope mount with the cartridge in place.
But if he does mean a powder burner than yes. Most scopes that air guns use are the same scopes real guns use.
Airguns are a class of real guns, firearms are another class by design and lawful regulation.
Re scopes;
Airgun scopes are generally comped for shorter distances where airguns are effective, and further classified for robustness for spring piston gun recoil. PCP airguns are noisier than Springers, but essentially recoilless.
regarding the UTG Mini-SWAT scope, and cartridges, vs air guns.
Springers are notorious for breaking scopes that centerfire powder burners don't have issue with. The springers and air displacing ram systems have two kicks per shot, and, that breaks scopes.
As mentioned, PCP is louder, but, there is absolutely no kickback in the shot; zilch.
What I accidently did to test my UTG Mini-SWAT scope, and one I do not recommend to others,... is the drop the rifle from a position which had the butt on the ground, and letting it fall directly on the top turret, the elevation turret of the scope test; and then in the same motion, have it rotate over, and landing on the windage turret. Oh yeah,... did I mention that this was on asphalt?
*Result: slight scratch on the elevation turret. I picked it up, and, we started pulling off center, because the drop also knocked the barrel off center; twisted out of true, and held by the barrel band.
Barrel band and barrel straightened up with an Allen key, and, scope held true, and, has for some very intense workouts.
This is one badazz piece of gear!
*edit
: Oh yeah,... I also broke the plastic flip cap off, on the objective end of the scope. So, now it is sporting the extremely ghetto Gorilla Tape enclosure mod, with toilet paper on the inside of the tape to keep it from collecting too much dust. I need to work on replacing that cap.
Yes they work. You might have to use higher scope mounts. My urban is a 10 shot and you can see there's plenty of room for the mag. IMG_0905.JPG
I had a feeling that my scope aim had changed a wee bit, when I took it off to see if I could get a camera to work with the scope; no go. But, in reinstalling it, something was slightly off, a tad high and right.
So, i set up my pellet trap, and, re-zeroed. This always leaves questions about how it will act, given the same shots at rodents (ground squirrels) and their trails to and from the burrows. I have those shots logged, regarding elevation settings and windage corrections.
So, I went back out to my most common shot, and I look down the scope, and there was a newly fallen macadamia nut right where the rodents emerge from their den, which is entrenched within a "cherry picker" motor hoist.
So, I took aim at the newly fallen nut.
As a side note, Mac.Nuts are the hardest nuts in the world, very tough nuts to crack. They're about the size of a ping pong ball, when fresh, in their green outer shell.
So, I take aim at the Mac.Nut at 200', and let the pellet fly. I watched the pellet as it hit the nut, and exploded it. The top part of the nut disappeared. The bottom half stayed in place to mark the spot. Some Sage Rat has probably already eaten it by now.
It is always a surprise when it works out that well.
Yesterdays score: One Mac. Nut, and a whole bunch of holes thru paper plates while dialing it in.
Todays score, so far: One thru the bottom of my new aluminum can from a Hansens Root Beer, with my P17 177 pistol
I am still waiting for the time to purchase a new setup, which will include the rifle, scope, compressor and appropriate hoses etc. I have been waiting for a stock market event that was supposed to happen in June, but will happen in early 2020 according to the latest announcement. I have a lot of land, but not many animals that I would be interested to shoot here, although I just found out from my mechanic that I had rats living inside the cowling of my tractor. I have never seen any out in the open. I guess I'll have to arrange some target system to shoot at. As a kid, I was a pretty good shot, but now I have essential tremor which gives me a pretty good hand shake sometimes throughout the day. It is not a terrible thing, but is a pain sometime. At least it is not Parkinsons, which was what I feared before my visit to the neurologist. I am going to try to find a rifle that is of a higher weight, which will help in controlling my shakes. I appreciate all the knowledge I have gained on this thread.
Just my opinion, but $ for $ it's hard to beat a Benjamin Marauder for a first PCP.
Lots of "nicer" stuff, and well over $1000 just for the rifle if you so choose.
I assume you know about Pyramid Air? Great folks to deal with.
Re scopes;
It's amazing what a big springer can do to a very expensive center-fire scope. They are not built the same (air gun scopes). The highest G recoil pulse is actually backwards on a springer. This is what can break a traditional scope, even a good one.
Earlier in this thread, I had determined the the Marauder was going to be the one for me. I am still studying pump, scope, pellet and all the accoutrements. I am glad I have to wait for the money, It gives me time.
I’m taking the slow approach with my Crosman 150. Next I’ll look into making an aftermarket trigger work in it.
A rifle that doesn't shoot straight is easy to beat. Unless Crosman has stepped up their game, 8 out of 10 M-rods with factory .177 and .22 cal barrels don't shoot straight. It's the barrels, cheaply made by Crosman.
If you want to drive tacks with an M-rod, get the .25 or be prepared to replace the barrel on a 177/22 or have it professionally trued and tuned.
Pulled randomly from stock, a Hatsan AT-44 will embarrass an M-rod all day long starting at the cash register.
Interesting. They get great reviews.:dunno:
From where are you getting the negative feedback? Just curious. I don't own one, I'm and RWS/Diana guy for now, but wanted to try a PCP. I had a beautiful Hammerli that had a trigger that was just awful, so I guess they all make bad rifles.
Experience, both mine and a good friend's. We learned too late that the .25 M-rod barrel was outsourced from another company and shoots very well. This is now going on several years ago, and Crosman may have improved the .177/22 barrels byt now, or not changed a thing. We both bought M-rods in .22, and with all manner of pellet neither of us could get 50 foot groups smaller than about 3/8 of an inch(my DIsco shoots a bit tighter than this). That's certainly smaller than the vital zone of most any varmint or pest. I wouldn't go as far as to say they're a bad rifle. But, we were looking for tack driver performance. And for me, even if it had the accuracy the railroad tie sized forend was gonna be a deal breaker for the factory stock.
My Hatsan ATP2 with it's factory Lothar Walther barrel will happily put a 5 shot group through the same hole at 50 feet, maybe open it up to .260 or .270 from .25 cal. The ATP2 is a pistol with 10.5 inch barrel.
I've had great experience with the Hatsan product(plenty of Crosman/Benjamin too)
Same friend just recently bought the Hatsan compressor, pretty sure i'll be taking that same plunge when i can afford it.
It's a $100 option, but you can get a Lothar Walther match barrel on the Marauders now. I've heard a lot about Hatsan in the last few years. I'll have to look into them. I'm getting ready for a PCP and certainly don't want a dud. I'll probably keep the RWS 48 for pest control, but the RWS 350 can go to someone else if I get the kind of accuracy I'm expecting out of a PCP.
3/8" at 50' for a PCP isn't very impressive. Like you, I'm expecting near one hole accuracy at that range. 1/2" at 50 meters would be really nice. I have a 10 meter range in the basement, so I can shoot whenever I like.
My .22 rimfire will shoot well inside 1" at 100 yards all day, with the right ammo and no wind, and if I don't have too much coffee. ;) I expect a good air gun to shoot better than a rimfire at 50 yards.
Talking about barrels? Some say the FX Smooth Twist X Barrel is one of the most accurate. Better than the LW. :naughty: Here's a barrel I bought but haven't installed it on my rifle yet. It shoots bullets. ;) It will make my day. :rflmao:IMG_0930.JPG IMG_0916.JPG
The rub is that springers generate recoil in the opposite direction that scopes are built to take recoil.
Even an amateur can ruin a top shelf scope with a bottom shelf airgun.
@bowtie427ss
I've had one experience with a springer and what it did to a scope.
As I've suggested, ad nauseum, we have a vermin issue here, ground squirrels. Pretty much all of my neighbors take them out in one fashion or another. One neighbor in particular had heard that I was whacking them, regularly. He wanted to know what I was doing, and if I would take a look at his rifle. Reality: I'm a total newb in this game.
I looked at his scope, and, his crosshairs looked like this X, not this -> +
So, I took his mounts and loosened them, and reset his scope, and rezeroed it for him. He came back the next day, celebrating a whacking of rodent. He was shocked.
Then he came back a month later, and, his scope was back to X
So, I had him order himself a UTG single piece scope mount set (two rings mounted on a single soild base).
He now stops by, and, everything seems to be holding as last zeroed, and stable as far as it not becoming an X. And he is now complaining similarly to mine; out of rodents.
