Air Guns
Just so everybody realizes that my .30cal pistol is not CO2 it is HPA. That small silver tube gets filled with air at 3600 PSI. :yikes:
What does HPA stand for? I always called them PCP's (pre-charged pneumatics).
What's the brand and model? Specs (pellet weight, fps)? It sounds very interesting.
I've seen the larger caliber rifles, even the "air bows", but I have not seen a pistol.
Probably, but aren't they all other than CO2? I guess it depends on the definition of "high pressure". It's just not an acronym with which I'm familiar.
Me neither, just a guess. PCP is usual, but single stroke pneumatics might be HPA guns.
It used to be that HPA meant you had a vessel (hangy tank) attached to your rifle/pistol. The tank had a high pressure fill and was regulated to allow about 950 psi into the gun eliminating the need for a high pressure air tube and pinned valve in the gun. Now I think the terms HPA and PCP are synonymous as there aren't many guns running hangy tanks. Some of the older Crosman Mark 1 conversions like the LD guns still have them but most new builds have a high pressure air tube on the gun itself.
I have a Benjamin 347. Have 2 Sheridan Blue Streaks and resealed a dozen or more of them. By this time, seals are brittle and leaking. Pump cup is hard and not giving good pump pressure. A refurb is in order and it will work like new. If you're not comfortable doing it, send it off to Rick at Precision Pellet. Too nice of a gun to not have it working good.
Thanks for the tips Bill
I pulled the pump out and the cup
is junk. it has a small piece missing on the edge.
I'll start with a new cup and go from there.
You are right it is a PCP. Some refer it as HPA. It's like voltage 210 or 220. ;) I just wanted to people to understand that it was not powered by CO2. There is no brand sort of speak. It looks like a Crosman 2240 but only the trigger group and handles are Crosman. The rest is custom parts that I bought or made. It shoots pellets and slugs 44g to 50g that I've tried so far. Haven't ran threw the crony yet but with only a 6" barrel I wouldn't expect much. In the 500s fps maybe. It only holds enough air for 3 shots. Depending on what the numbers say I will tune it for 2 Higher power shots.
That's a good place to start. Lube it with non detergent 30 weight or Auto Trans fluid. A couple drops in the tube where the air intake hole is as well and sit the rifle on the butt pointing up for a day or 2 to get some oil on the valve seals. That will expand the rubber a bit and buy you some time. Then a drop or two on the pump lever pivots.
Another thought on this for you RF. Sheridans can be surprisingly accurate with the right pellet. The old yellow box ash can pellets were terrible. The red box domed Diablos were much more acccurate. Try some JSB .20 cal domes for real accuracy. You don't need 10 pumps. 5 for groups will do.
Same with pellets for your spring gun. I have more than a few vintage German and UK springers and most like the H&N FTT - field target trophy. My rifles will all shoot dime size 5 shot groups at 25 yds if I do my part. My rifles have very good adjustable Rekord and Diana triggers though too. Shooting springers with the double recoil is challenging but rewarding when you shoot a good group.
While it's probably fine on the lower powered vintage pumpers, a fella is lookin for trouble using petroleum based lubricants around HPA/PCP equipment.
It's a safety issue, folks need to know what they are doing.
Take a SCUBA class, or ask a certified instructor for some HPA safety tips.
Some of today's springers and nitro-pistons develop enough barrel pressure to detonate.
If it will shoot 550 fps with a 50g slug that is about 33 fpe. That would be pretty amazing out of a little gun.
Technically grains are designated "gr", grams are "g". No offense is intended.
I can't help it. I'm an engineer and an ISTJ (see Meyers-Briggs personality types).
Dieseling (compression ignition). There are some folks that do this on purpose. It usually results in blown seals.
My RWS/Diana 350 will diesel if you look at it sideways...It's a big springer. The Model 48 is a bit more tolerant.
Well I only have a 6 grade education so doing the best I can. :rflmao:
I have a 48 in .22 with a Tyrolean stock I don't take out and enjoy nearly enough.
I was referring to MSP guns. They will not detonate. Too much oil and the valve hydro locks. A Springer is usually lubed with a thin coat of moly paste if it has a synthetic seal. Leather seals get silicon or a silicon Neatsfoot oil combo. I've been around a few airguns.
I used to have a Gamo, it's gone. Just ordered a Weihrauch hw95 setup, .22 .
I have 3 Gamo Urbans. 2 in .22. I liked the feel of it and the way it looks I ended up building a .177 one also out of used parts I bought. This is one of the .22s. IMG_0906.JPG
