Saw them ZilchPlugz there, didya?Now just for giggles, what happens if you plug the port?
Ray
Nearfield was done with the port plugged, actually.
[That's how they get down to 30 Hz....
Ray
Saw the ZilchPlugz there, didya?
[That's how they get down to 30 Hz....]
It's about placement, of course.How's the sound between plugged and ported?
Yes, basically.Over simplification but does ported = "West Coast Sound," and plugged = "East Coast Sound"?
My test/measurement system uses 40 WPC JBL 6210 pro amps.I realized no one's asked this yet. What are you powering them with, Zilch? :scratch2:
$250 using the prebuilt PE rectangular cabinets, but this is DIY, and the cost of admission can be substantially less, depending upon how they are packaged.Great job Zilch.
If they have the ability to be used both ported and unported I guess that kind of makes them "bicoastal."
We're at about $250 total cost here. I know you're still tweaking them but do they best most commercially available speakers in this price range?
The woofer sets the baseline for system sensitivity, and these are 85 dB/W. Before we're done, I'll try them on Sonic Impact T-Amp.
Others are going to have to hear these for overall listening evaluation, but I can certainly say the bass bests anything I've heard in this small a package. Ray apparently knew that when he first recommended this woofer, and we bumped the cabinet size up to 0.38 cuft. primarily to accommodate it.
There's no denying they are "entry level," and they're monoblocks, so I have built up a stack of four of them over the years.How is the 6210? I was going to buy one and was told it isnt in the same class in terms of sturdiness when compared to its bigger brothers 6230, 6260, and 6290? I think I already know the answer if you're using one!
I've heard good things about the Dayton DA175. With an aluminum cone the LP might get a little more complex than we want but it's fairly inexpensive for a normal (non-sale) driver with good performance.
Order up the stock baffles. By the time you get them, I should have the layout posted.I'm trying to figure out if I want to do a plain jane MDF to show how easy/cheap it can be or something nifty looking to show that it really isn't all that hard. Thoughts?
If 6215s weren't so darned expensive, I'd probably be using one or more of those in a short rack with the other test gear.... :yes:
Page 1. Heh....:
That way, you can put whatever design you prefer behind them, or they'll pop into PE finished boxes, should you decide they warrant that, and you'll have a spare set for an alternative driver set in your original cabs.
[Cooling racks optional....]
Wiredbecker: "They sound like you have a sub running here."
Zilch: "Nope, that's 100% Indignia bass...." :thmbsp:
