Hello Steve, now I understand everything correctly.
I could read and translate your last two entries well.
I don't have a parts list as such. I followed the circuit diagram.
I myself chose Elna Silmic Gold on the audio board.
Experiments with others, Panasonic, Nichicon Audio FG, result in these beautifully clear mids and very light frequency emphasis around 15-20kHz.
Coupling capacitors Wima Folie. In Wima Styroflex equalizer networks. Headphone amplifier Philipps polypropylene.
I also installed Philipps capacitors measured in pairs.
At the time, these were recommended to me by a Mr. Burmester from Berlin at the radio exhibition.
In general, all coupling capacitors or areas used in frequency-influencing areas are measured in pairs.
Power supply Elna Cerafine. Additional 2.5mm² power supply from the Syscon to the audio board.
Components all ordered from Mouser USA.
Yes, the chassis is covered with alubutyl, in addition to soundproofing against drive noises of the mechanics with fire-resistant insulation for air conditioning systems.
Extra tip: large relay coils on the chassis become quieter in operation if a little silicone spray is applied to the pistons. (Pause / FF / FRWD)
Counter is self-made. Originally it is like you.
Greetings Andre
Greetings Andre
