DijonMaster
Can you slide that cart backwards towards the tonearm base?
What do you mean by slide the cart backwards? I can pull the arm out and slide it in, but all the way in its still not short enough
Can the cartridge be loosened and slid back towards the tonearm’s mounting base a little bit?
How is it attached to the headshell? Usually the mounting screws pass through slots (rather than circular holes) that allow for positioning.
ok. so the whole arm tube slides back and forth to get the correct overhang?
If you cant hit these numbers, the cartridge isn't compatible with this arm then.
(Well, technically you could remove the cart mounting screws and either use foam tape or glue to mount the cart further back in the headshell)
There is a small screw under the arm wand where it enters the pivot block which can be loosened to adjust both overhang and azimuth. AR included a small screwdriver with an overhang gauge and other items for setup. There is no adjustment at the headshell.
I believe Marc covered this somewhere in the official AR thread and I seem to recall the cartridge mounting hole to stylus distance changing over the last sixty years. Regardless, more adjustment is one of the benefits of changing the wand to accept slotted headshells.Yeah, the whole tube slides back and forth. The lowest I can get between the spindle and tip is 18mm
I had a busy day and see I missed a lot here. I’ll post this picture but I believe AR supplied two different overhang gauges over the years; 15mm and maybe 18mm. I have one but I don’t remember which one it is. Regardless, either clearly illustrates the concept of overhang. no affiliation with the source.
Edit: I can’t seem to post the pic and I hope the link is acceptable.
https://www.patsaudioparts.com/single-post/2017/12/10/ar-xa-turntable-and-setting-overhang
use a very simple jig to align and set the overhang of cartridges on my XB. I took a scrap piece of trim and carefully drew a grid and drilled a hole for the spindle. I suppose my jig could be thinner, the height of the spindle, but I don't have any complaints.
And you align to 16.5?
You guys may know something that I don’t but I go by the data provided by Edgar Villchur, the Designer of the AR XA Turntable and Tonearm. In his two part article “A New Turntable-Arm Design” published in the September and October, 1962 issues of Audio Magazine, he states:
Pivot to Stylus. 9” (228.6 mm)
Overhang, 0.688’ (17.475 mm)
