I happen to have two AMI model AA jukebox amps. These would have been in the Model A "mother of plastic" jukebox, so each is single channel, and the jukebox would have played 78's. They need some rebuilding or recapping at least.
Since I have two of them, I was thinking about trying to set them up as monoblocks. I don't think these are rare enough that it's a big loss to jukebox collectors. Tube complement is: 6SJ7, 6SL7GT, 2x 6L6, 5U4G.
6SL7GT is listed as the phase inverter, so all the preamping must be happening in the 6SJ7?
I don't really expect them to be "hi-fi" per se, but thought they might be fun to keep in the garage or something. I'm guessing there was only one preamp stage here, rather than a separate phono stage before the preamp? So maybe the best route is to just remove the 6sj7 stage so I can run these as power amps with a separate preamp. That should also remove any 78rpm eq curve stuff built in to the preamp. Thoughts?
