thats just how the math works out based on the stuff in the datasheet. It will be slightly different in the amp since voltages and such aren't quite identical but it should be reasonably close. sqrt 17.5 * 5000 = 295.8
in reality the plate to plate power doesn't matter that much. Its the power to the speaker that matters. I only mentioned it because what you'll see in the datasheet for power output is not going to be what you can measure at the speaker.
split, inverted, and re-combined is pretty much exactly how it works. The tube ahead of the 6L6 stage is the phase inverter. This one is a paraphase type so it uses 2 triodes, but that doesn't really matter. One input, two outputs 180 degrees apart. In the earlier days, a transformer was actually used for this, but you can get it done in a number of ways.
Unbalanced input comes in at pin 1 grid of the 6SL7. Triodes invert phase just because of how they work, so a 180 inverted output appears at pin 2. That signal is fed to the grid of the upper 6L6, and back to the pin 4 grid of the 6SL7 through some resistors to knock the signal down. The output is inverted again so the signal ends up in-phase with the original input signal. That goes to the lower 6L6 grid so signals from grid to grid on the 6L6 are 180 out of phase. The output transformer essentially re-combines them to a single output.
