What do you mean by "very hi-fi sounding"? Just curious.2x output tubes usually mean push pull which should be very hifi sounding
A 6L6GC won't do anything the 6L6 won't. It might last longer since its running way below max ratings but it will not give more output power. You'd have to re-design a few things to make use of more voltage to try and get more power, and then you might run into limitations of the output transformer.
We might be talking about different relays. The one I'm looking at sends 11 volts to the 6L6's until they're warmed up then the relay trips and drops it back to 6.3 volts.The relay is there to turn the turntable on, in case the mech pulls and loads the record before the amp's warmed up, which happens, esp as the output tubes get old. You can actualy hear the sound quality change as the thing warms up for the first few records.
Frankly the early AMI jukebox amps weren't anything special in terms of sound quality, and like the others at the time put out more light and heat than sound.
heater booster for faster warmup then? Interesting. Probably doesn't do the tube life any favors at all.
Looks like you can ditch the relay and move the heater supply to the Green / Yellow (I think thats G/Y) wire. Whatever is on the normally open relay contact.
I would probably dump the relay coil and sub it for a resistor to bias the output tubes too. I can't quite read what it says the coil measures at so you might need to experiment a bit to get the cathode voltage right. The resistor is there to get the total resistance correct and to limit how much current flows through that relay. The resistor and the coil in parallel form the cathode resistor so it creates bias for the output tube. Since no current flows until the tube warms up some, its a reasonably effective way of kicking the relay only after the tubes are hot enough to conduct.
Thanks, any chance I could beg you to explain the napkin math? I'm trying to learn some theory as I go. Since I was looking for resistance I'm guessing I would need to already know a current and a voltage. It looks like "k" stands for cathode in the pinout on the schematic and that specifies 18.4 volts? How do I know what the current should be?Its in series with the stock resistor, so likely yes. Some back of the napkin math makes me think it wants about a 120 ohm resistor for things to work out properly, and the resistor looks like a 62 ohm part. Sub it for a 120 ohm 10w and you should be fine.
6L6G datasheet gives us operating conditions for a class A pentode push-pull stage at 270 volts. It specifies 17.5v of bias, 134ma for the plates, and 11ma for the screens for a total of 145ma. 17.5v / 145ma = 120.7 ohms, pretty darn close to what the schematic values for the resistor + coil come out to be. If the output transformer is somewhere near the 5k specified on the datasheet, that should give 17.5 watts at the plate, or ~15 to the speaker.
Unless you meant power. If you were to measure AC voltage from plate to plate and use that number and the specified 5k load, you'd get 17.5. Transformers are ballpark 85% or so efficient, so that leaves you with near enough 15 watts at the speaker. Might be a bit one way or the other if you actually measure it.
