Amp setting pls help.
GGG
Hi to all! Pls help me with my yamaha dsp a1 setup.
Im not sure whats the best Parameter settings just for stereo music listening use. Im using it with a pair of la scala, Plus a 12inch sub. Thanks in advance.
Not familiar with that one, but usually set to Large L&R or 2 CH stereo. Use crossover at sub to integrate with speakers.
Welcome to AK, Since your your using full range speakers and a sub you should set in the speaker settings , Speakers set to large and for subwoofer select Both. When listening to music listen in stereo , if you select processor Direct keep in mind that will disable the subwoofer .
Audiofreak71
