Amplifier Distortion, DC-Offset, and You!
I am pretty new to this and have just bought myself a meter and a few other bits of test gear.
I am getting a wide range of figures across my collection of ebay bought receivers so far:
Aiwa AX-7600 Right 3.6mV and Left 2.8mV
JVC JR S-300 Right 9.0mV and Left 5.0mV
JVC Nivico 5500U Right 290mV and Left 327mV
L&G 3400E Right 2.8V and Left 3.4V
I have checked with 2 different meters and they are consistent, but the L&G is certainly crazy high so I will need to investigate that further.
The Nivico needs attention as well.
My readings Fisher RS-1080
  • Negative -98 when i select the channel A the one in question.
  • +117 when i turn it off
So im wondering if its in short? Or i have set the multimeter in wrong configuration.
I have to say it already ruined one of my speakers
Thanks for the advice.
Should be measuring DC mV across the speaker terminals, volume zero, no speakers connected.
Are you sure that L&G receiver is DC coupled and not capacitor coupled at the output?
Thanks. You could well be right on that. I have found an AK thread from 2018 that also mentions that may be the case. I have had no luck so far finding any schematics but am still searching. It certainly seems to run hot.
If this is the case, putting a load across the output should null it to nearly 0V. It doesn't even need to be 8 ohm, it could be 1K or something... anything that's enough to overcome any slight current leakage in the output capacitors.
Thanks very much. I tried that with an 8ohm dummy load on the original L&G 3400E and also on an L&G 3600 EL that I picked up subsequently and in both cases it dropped the reading to zero or thereabouts.
I used to be the one that did warranty audio repairs on Fisher, Pioneer, and Phillips in the early 90's, but worked on other stuff. Had a Fisher that gave me fits with this issue, no access underneath, and stacked board. Had a blown channel, plus this issue once done. I think it was the differential pair causing it. Been too long ago.
