Probably the first question you might want to answer before buying any equipment is where you really want to run both pairs of speakers simultaneously. It's not unusual for 2 speakers to sound better than 4. If you have all four speakers in different corners of the room, for example, some frequencies will cancel each other out and some will be boosted. Probably the best chance of 4 speakers sounding good is to stack them and make sure the speaker pairs are in phase. Still, you should try to listen to all four vs two. You could drop one Emotiva amp if you were only running one pair of speakers.
Thank you for coming back as well! I agree totally with deciding on running all four speaks at the same time vs one pair at a time. This all started one day when I was in our basement looking for something and saw the old beat up Vegas in the corner. I have been wanting to fix them for years so I drug them out and the restoration began. Drivers and crossovers totally rebuilt, cabinets refinished, even made new grills and covered them myself. Got them done, wired them to the amp and I was very happy with the sound. Then I saw the Bose at a antique mall and ended up with them. Since the amp supports two sets of speakers I though why not use all four. I just wanted to explain why and how I got to this point, I picture you guys rolling your eyes and wondering why the heck would anyone do this. Well it just fell in my lap hahah.
So, I do listen to them both independently just to compare. In short the Vegas sound better but the high end is crazy, its like the tweeters are too much. The bass is what you would expect from Cerwin Vega, its awesome! The Bose sound good too but seem to lack the high end, they sound dull, like they need tweeters. Bass on the Bose is fine.
So now, all four together sound best to me. The Bose seem to fill in that midrange that the Vegas lack and the Vegas seem to provide the highs. The speakers are all on one wall ( 14'8") with the Vegas on the outside and the Bose positioned in the middle based on the recommended spacing from Bose. Now, one thing I have considered is placing the Bose on a different wall, its about 18' long. Keep my Vegas where they are and listen to one or the other. The Bose might sound better that way but the Vegas will not change. Problem is that it would take 50 feet or so of speaker wire to move the Bose to the other wall and from what I read that would require some hefty expensive wires.
So I am confident that you guys have picked the perfect setup for what I want to do. I think separating the Vegas from the Bose EQ is great and the flexibility to add the ADC to the Vegas is wonderful. The only thing I'm concerned about is will this new system be the one for years to come, will I be able to add anything or not, will I want to? I cant see needing anymore then a turntable, CD player, tape deck and my phone. I think the new system has it all and should serve me for many years possibly my lifetime. I think most likely any upgrade from here would be better speakers. But for now With the money invested in the speakers I have I need to use them for a while.
So here is my final thought. If I were to get the new gear I can get the Vegas away form the Bose EQ and dial them in with the ADC making them sound better. The Bose I just hope will improve with the cleaner amp and maybe the DAC will help too, not sure. And if I were to listen to one set at a time I can use the inline volume controls or some sort of speaker switch. All in all the Emotive gear is the best bang for my buck, I will never have a 50,000.00 system.
Thanks again, I appreciate everything very much!
PS, I attached an image I have been working on so you can see the current speaker placement.
Jeff
