Okay, I get the male couplers allow me to use the volume controls as RCA cables, I don't think they will be long enough so I might order some 12" RCA cables like these.
Okay, I will take your advice. This product says cable lenght is 7.5. This will work correct?
Amazon.com: Universal RCA Level Controller Car Amplifier Audio RCA Amplifier Gain Level Bass Amplifier Volume Control Knob Sub Amp Volume Control Cable for Car, Motorcycle, Speakers, Home Theater : Electronics
Buy Universal RCA Level Controller Car Amplifier Audio RCA Amplifier Gain Level Bass Amplifier Volume Control Knob Sub Amp Volume Control Cable for Car, Motorcycle, Speakers, Home Theater: Amplifiers - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I think the FedEx people lied to me, hahah.So... what do you think?
Thank you! Boy the ideas just keep flowing in. Will this degrade the sound quality in any way? Not an expensive item which is nice.
Thanks for the recommendation! If the ones I purchased don't work good then I will try that.A Schitt Sys is reasonably inexpensive ($50) way to add a a switchable volume in line without too much signal degradation ..
It's at least using an Alps pot which has a reputation for decent sonics ...
Thanks for the advice! The Vegas are louder than the 901s so the volume control will be needed eventually. I will try disconnecting the Bose for a while. Last night I was very pleased with the sound. The cd player seems to sound clearer than the tt but then I'm using an old Shure M97xe cart with a repop stylus which I had to sand down to get it to slide in.I'd encourage you to listen systematically, with as little in the way to the speakers at first. Hook up just the pre-amp to the amp and the Cerwins, listen for a bit. This will give you a sense of what the gear sounds like, then add in the additional electronics. You may find the old electronics aren't helping, but actually hurting.
I know that the 901's really need the EQ, but its worth trying w/o it, then adding it. This may trigger you to notice something. As you've already experienced, these old electronics need service often.
Funneling the signal through two vintage EQ's creates many possible points of failure. Also don't be afraid of the Bass and treble controls on that pre amp.
