PeterSchut
Things are getting out of hand
Hello Forum,
Things are getting out of hand …. (that is not new for me ….)
I have been working a lot on the design of an EV based surround system and want to share what all happened.
It all started after I bought 2 VMR’s and 2 ST350b that I mentioned at the beginning of this thread.
Since then I bought:
- A set of Swiss made Interface Delta’s – The foam surrounds are renewed
- A set of Swiss made Interface 300 (close equivalent to the Interface C)
- I found a single ST350a in perfect shape (future center speaker)
- And last weekend I ran into a Sentry 500 and 2 extra ST350b’s that I couldn’t resist.
(see attached pictures)
The 500 is quite a nice speaker and the woofer is the closest thing to an Interface D woofer, but still different. As you can see in the pictures it is a shallow or short basked with magnet structure from a Force 12, were the original Interface D woofer is the longer/deeper basked and magnet structure from the famous EVM12L.
The tweeters of the 500 are the well known HiFi tweeters from the Sentry 100a and Interface C but then mounted to a very pretty wooden horn. I have no real plan for the 500 parts but the enclosure has seen better times, and I might try to put it in an enclosure like my Interface E design but then as a 2 way front loaded system.
The design of the Interface E is getting more and more shape see attached PDF.
The filter parts are ordered for a full rebuilt of the passive filter with all Mundorf high end caps and air conductors.
So far for an update.
Peter
Hello Forum,
Peter
