Wouldn't raising them off the floor decouple the woofer from the floor to some degree?
I'm not an engineer but I always thought a boundary helped the low end a bit. Put next to a wall for example or in a corner...
Thanks, guys! Mine are Interface D. The VMRs look identical to my pro versions. You were keen to discover the subtle VMR differences between them. In some instances, I had to reglue where the VMR surround attaches to the plastic housing. Apparently the glue didn't survive thirty plus years on that slick plastic. Pretty easy fix though. Your designs look gorgeous, Peter! :-D
Well absolve 2525, they look great.
Probably the best looking Interface D/Sentry VI is saw on the web.
Are they Interface D or Sentry VI as the ring on the VMR was only used on the Sentry VI, where Interface D had a black metal with silver trim. But that might not be an absolute rule.
The stand is something I saw before as the listening sweet spot of the Interface D is between the ST350 and VMR is a bit low.
It will influence LF response a bit I would guess as you will have less coupling to the floor but that might be a good thing is some rooms.
My latest design will solve the listening height. It is a bit less wide as my original idea and a bit taller.
See attached. the wood in this concept is ebony/makassar.
Thought I would jump in and show my EV Sentry VI's, they do look just like the D's.
Tim
If you'd share the box dimensions of your homemade IE's I'd really appreciate it. I have been to listening to my iteration of the D for weeks now and I am blown away. I searched for a suitable woofer and the CV 12 is perfect, but if I get the proper box dimension for the woofer, I'll pick up the 12 you're using to round it out. Thanks in advance. These are awesome.
Well Tim, bot sure if I mentioned this before but I have the original hand drawn design drawings (with great exploded view) and this drawing is called Interface D/Sentry VI. So they appear to be one design,
In base they are exactly the same. It seems that originally the Sentry was not shipped with EQ, my drawing makes no difference between the two.
I have a Swiss made Interface Delta, and in some details this enclosure is diffident. It does not have the rounded bottom side of the front lower panel and the VMR is not recessed although I am not sure the US version has a recessed VMR, but my drawing shows that.
Attached a picture I grabbed from the web (copyright to its owner) when I was gathering all information I could get. This picture always puzzled me as the port is a round hole with no depth, so the tuning is really different.
I have no hopes of finding the original woofers, sadly. The CVs are working well, yet, I'd like to put a JBL or other pedigree in there. Any suggestions?
