I received pictures of the original Interface C/D EQ (thanks David Wojnarowski) and could verify the resistors for the interface D filter.
Who would be interested in a generic Interface Equalizer?
I am going to design and build a couple of PCB's fully functional EQ.
A single PCB with a stereo input, stereo output, a single power LED. Internal Jumpers for the 10kHz 3dB boost, a jumper that attenuates 10kHz by 3dB and 10 Jumpers per channel to configure for 29, 31 (interface D), 33, 35 and 38 Hz.
Selectable 230V or 115V AC mains and fully tested.
The schematic will be equivalent to the original with slightly better caps and all metal film resistors.
So what you need to do is get an enclosure, drill 4 RCA connectors, a mains inlet and if you like a front panel LED.
For my own setup I will put two stereo PCB's in one enclosure. One connected to the LF amp and one connected to the MF/HF amp.
One input driving both equalizers.
The price of the board will depend on the amount of PCB's but will be very reasonable + shipping (maybe a batch shipment to the US)
see attached schematic of the original Interface A EQ as I bought on Ebay with improved (flat) frequency response, and on the second page the new design.
