Today's status
Hi Guys,
I have found a suitable 10" woofer for the surround speakers. It is the Eminence Deltalite II 2510. It is the only unit I could find from any brand that works well in a 60 liter enclosure, is loud enough (97db 2.83V/1m) and has the right TS parameters to get a decent frequency response.
I used the Interface 300 enclosure to perform a test with this driver (with 70 liter and tuned around 40Hz) it was close enough to perform a test with the pro VMR, an ST350b and the Interface D filter. The new enclosure will be 60 liter tuned at 50Hz.
The filter (without the 2.5ohm in series with the woofer) works great. I only need to change a value in the VMRpro to ST350b x-over. I lowered the 1.3mH (in series with the VMR) to 0.8mH and I had a perfect flat response. The original filter had quite a hole in the 1-4k region that I didn't understand. Possibly the 9µF needs to become 4.7 to 6.8µF. Also the larger distance between VMR and tweeter influences the measurement quite abit depending on microphone position.
This hole is not visible in the interface Delta measurements with the different Delta VMR and ST350a.
The Eminence 10 inch will be slightly less ideal for the 27 liter Interface Center enclosure but just OK. An EV Force 10 would do perfect here, but they are hard to get, or just too expensive (US, transport, VAT)
Attached the set as it stands now, the Interface Epsylon front speaker, The interface Zeta surround speaker and the Interface Center.
Also two pictures of the Interface 300 with Eminence woofer, VMR pro, ST350b and closed hole where the original tweeter was.
Cheers,
Peter
