Hey Peter, I must say this has been a most interesting read. I own a pair of 'D's and will not be looking for any other speakers for a long time. I am currently running mine Bi amped through a Yamaha SP 2060. This unit has the capability to almost dial up any parameter for EQ and crossover you wish. Prior to this setup I ran the speakers through the EV C/D equalizer and a rotel amp and loved it. Now I run it through 2 old BGW 750B power amps rated at 225 watts with no EV EQ. The sound is amazing and "loud!!!!" I have tried to simulate the SP 2060 with what info you have provided in your findings of the EV EQs. The results are stunning. My reason for contacting you is regarding the VMRs are you aware that the magnet arrangement is identical to the 12inch woofer of the 'D's and that a basket from any 12 inch ev driver should fit straight on and it should be able to be reconed pretty much the same as the woofer. The voice coils would need to be checked for a match. I say this as it is a lot easier getting hold of the VMRs than it is the woofers. So as a result of your thread I am on the search for some VMRs I have a pair of the horns from a pair of Sentry IIIs that I own. BTW the Sentry IIIs sound horrible compared to the D's. Thanks again for all the effort and info gathered.
Hi Don3128,
The Yamaha looks a bit like the EV DC1. And indeed this can be used to dial in the required 6dB boost. According to the original designer D.B Keele from EV you need a 6dB @ 31Hz boost with a Q of 1.9. If that can be selected in the Yamaha it will be a perfect match.
I wanted to avoid any digital processing (even though this can be very good nowadays) as since early this year I am also back to using vinyl and I am so impressed how good this can sound (much much better than CD) that I want to stay pure analog all the way.
I might consider a nice analog parametric equalizer like the Avalon design AD2055 to tweak some room issues but not digital.
With respect to your remark on the VMR, I am not sure I understand you.
yes the magnet and voice coil diameter are identical to the woofer but I don't see how that would help making a new Interface D woofer.
The length of the VC is most likely different and even in the VMR there are 4 different voice coils. I asked my contact at EV and he mentioned that an EVM12L that has the same magnet and basket could not be turned into an Interface D woofer. The 2.5" VC of a VMR has a DC resistance of 8,5 Ohm (pro 5 Ohm) and the DC resistance of the Int D woofer is 3,5 Ohm.
I would love to have a spare D woofer set for sure
I still have two spare sets VMR but these are the pro ones that are very different from the Intf D ones. Although matching them with the ST350 is possible.
Could you please explain again what you want to achieve?
Cheers.
