voltcontrol
Fizheuer Zieheuer
True 'crowdsourcing' as they call it. :thmbsp: :thmbsp:
The actual RIAA equalization network is unchanged and designed by National Semiconductor so it should be very very accurate. The only changes that have been made are in the gain and loading with some DC blocking and radio interference added, so it should all be kosher. The values I have kept to around 1% to maintain accuracy.
Okay, here are the corrected values. These changes do make a noticeable improvement in equalization accuracy when checked via circuit simulator. ....
Are there any specific tolerance requirements for these resistors and caps?
Did you consider putting in the 10pf cap on the + input per the NS schema? Possibly filter the noise from the source?
I noticed in my Rod Elliot P06 and our current CNC that there is a slight rustling sound when you put your ear near the speakers, not just the usual hiss like sound you get when you turn up the volume a fair bit. In both cases it's below the level of surface noise during playback, not knowing if it affects the sound or not I tried to get rid of it to see.
Could that rustling sound be opamp oscillation? Do the opamps get hot to the touch in the circuit? Do you notice an increase in the noise as you touch them?
I've read of this before and that it's usually in the ultra-sonic frequency range. OTOH I have no experience with it so may be talking out my arse! :yes:
