Hi Grantray,
How and when did you get Isamu Asano amps??
I never knew these were made, I thought Asano was only a DIYer who had his circuit published, prior to Shishido's DC amp??
The Fi schematic posted in this thread shows no Hum Pot, yet you mention a Hum Pot, in two of your thread's posts.
Are you sure you have a Hum Pot in your amp?? If so, please allow me to mention something .......for you to consider.
Most DHT tubes using hum pots ( only ) have a ( fixable ) weakness in their design.
The interface between the pot's center wiper, and the pot's internal resistive element, acts somewhat like a diode, it partially rectifies the JJ 2A3-40 or 300B's cathode's audio signal, in the tube's return-to-ground path.
Designers / DIYers / people who are aware of this, simply add a SOLDERED pair of resistors, from each end of the pot, to the center ( wiper terminal ).
A typical resistor value may be 15 to 25 Ohms , 2 Watt, high-quality would be preferred.
This does several things, the most notable IMHO, is that you have changed the return to ground from a " diode - like / rectifier - like " wiper-interface, to a added - SOLDERED current - return - path, to ground.
Most who do this, report an improved sonic result, and your large / beefy JJ 2A3-40 or a 300B would benefit from such a soldered connection IMHO. Please look this up, on line.
I personally am a big fan of the two stage DC SET circuits, as you seem to be. Less becomes more. I have written a 32 page paper, tracing the history, and implementations of this specific amp type, ( from 1929 to 2018 ) and would be happy to email it to you, if you would like to read it.
I drew out a diagram, below, of where to add the resistors. Also, I can mail you (4) 15 Ohm, 2 Watt Cornings, for the cost of postage, if you would like to hear this.
Good listening to you !! I DIY build these amps from scratch, just for myself ( use ALTEC VOTT A7-800s ) and have done so, past 12 years.
Dowto1000
.Hello, I would be very interested to read your white paper on DC SET circuits. I’m trying to find a very simple design for a 300B amp build. I was drawn to the Don Garber design.
I really appreciate your consideration.
Brian in Seattle.
Frisbie55@hotmail
