Any Lafayette Collectors? Raise Your Hands!!
Purchased new, rocked many a party, my oldest son now uses it with the Cantons pictured, a very capable system indeed even 5 decades later.
"The LA-975 can also be operated as a high quality independent 2-channel stereo amplifier."
This has been it's function for almost 50yrs, a job it does very well with a sweet sound that just draws you into the music, it's also nice it has all those other features if wanted.
Actually the basic amplifier design used the LA-975 (especially the driver and the audio output circuitry) was also used almost identically in a number of Lafayette 2 and 4 channel receivers and amplifiers around that time period.
I still have my Lafayette LA-64 and LA-74 4-channel amplifiers that were active products around the same time as the LA-975 and they still work well.
My Stereo-10. I love it! Help me on my recap if you please! Open to any input. https://audiokarma.org/forums/index.php?threads/lafayette-stereo-10-recap.1022787/
im trying to add this pointless but beautiful piece to the collection right now too. It would make a gorgeous base for the Stereo-10. Plus it can get the weather bands and some some other random interesting stuff, I can probably run that from phone out on the front if it could handle it. That would be cool. The Phono input on my Stereo-10 is open.
The Lafayette "drifty" PF-60 FM receiver. These things were a pain to keep on frequency but "state of the art" back in the 60's.
If you want to do cool things with the Stereo 10 or any amplifier, get a Bluetooth to stereo interface adapter. Then you can send to the Stereo 10 any audio from your smartphone.
Ive sworn off bluetooth, I go straight from my phone or macbook to DAC. This would just be for novelty and looks.
ok I got the belt and put it in
I thought I screwed the pooch because I kinda bent a wire link for a bellcrank trying to take stuff apart stripping out screws torqued to 30 ft lbs but I removed a couple brackets and got everything back together
after that the tape would play but no sound except horrible buzz
I thought i was in for it because it had to be something electronic...beyond my skills...but...
per old threads here I just worked the hell out of the switches back and forth and slowly it started coming around and ultimately got it to work pretty good
I dont have any any deoxit...so i guess i got lucky
sounds pretty damn good but one meter is not moving
im hoping she will loosen up a bit and get better with frequent use
Some years back I found a LR-9090 on top of a garbage can while walking home from work. I called a cab and got her home. It worked great for 5 years and eventually I sold it for $150. The only issue was that wonky power/speaker selector switch. I got around it by keeping it in the last position [Speaker A+C] and powering on/off with a switched wall adapter.
Currently I have been listening to a LR-100 and while not the most power sounds pretty good imo.
Really like the design of those little stereo 10s. How does it sound? how does the sound signature/ quality compare to the marantz? (at moderate volumes)
I brought this home yesterday
ordered a new belt for it
Didn't see this post earlier for some reason. In the Lafayette line of equipment, there were very few that would give me a headache when it came in for repair. One was this RKD200 and the other was its "updated" version RK-D225. These decks seem to have a lot of underlying problems with them both mechanical and electrical. Even if it came in with "belt broke" as soon as you started working on it, other issues would raise their head. Maybe they were designed by Satan. :eek:
Greetings ....
The only Lafayette items I ever had were the catalogs, some from the late 1960s, and nearly all from the 1970s.
My cousins owned the Lafayette LA-750 amplifier, which offered an estimated minimum 10 watts continuous power per channel.
Would have liked to have owned the Lafayette LA-125TA amplifier, offered in the 1970 (# 700) and 1971 (# 710) catalogs. This unit put out an estimated minimum 22 watts continuous power per channel, good enough for most in-home setups with the right speakers. The LA-125TA had independently selectable magnetic and ceramic phono inputs, as well as inputs for tuner, aux, mic and tape monitor. With proper care, the ceramic phono input could have served as a 2nd aux input.
Regarding the LA-125TA's MIC input, you may note that it is a single jack, but is the 3-conductor type, same as the jack for stereo headphones. To attach two microphones, you needed a special Y-adapter cable. If a pre-made Y-adapter wasn't readily available for your specific needs, you could build one using parts offered by many sources.
The LA-125B, the LA-125TA's successor, first offered in Lafayette's 1972 (# 720) catalog, was tested by High Fidelity magazine in its February 1972 issue. The article concluded that the LA-125B was worthy of consideration. There was one downbeat observation - the ceramic phono inputs on the LA-125B were no longer independently selectable. They would be disabled when a magnetic phono unit was attached -- BUMMER !!!
Lafayette's LT-725 AM-FM tuner series has its own interesting history. The original 725 unit, as offered in the 1970 (# 700) catalog, included a switch to access SCA non-commercial programs on FM stations carrying such services. Within months of the LT-725's introduction, the FCC issued a ruling that home-based FM tuners and receivers could not be offered with the SCA feature. When Lafayette's 1971 (# 710) catalog was published, the LT-725 was still being offered, but with the SCA button (and, presumably, the circuitry too) disabled.
In spite of the FCC ruling, auxillary SCA adapters were readily available from many firms. SWTPC (Southwest Technical Products) was among those offering an SCA adapter in both kit and wired form.
The 725's successor unit, the LT-725A, was was introduced in the 1972 (# 720) catalog, with a MUTE button in place of the previous SCA button. High Fidelity magazine would test the LT-725A in its January 1972 issue. The test results ranged from good to excellent, and the magazine concluded that the LT-725A could be considered as "an above-average contender".
Thanx-A-Lotte from Frankosport4
Purchased the Criterion Mark III and 1007 speakers back in 1979
Wish I still had the receiver, my mom would listen to the radio all the time. Always noted when I turned it on it wasn't on my station! lol! Compared Lafayette to Radio Shack, fell in love with Criterion line and 1000 series speakers Compared to Radio Shack. Sold them years ago. Missed the sound of the Lafayette receivers, recently picked up LR-5555A running through Yorkville YSM-1 speakers. Always thought Lafayette was better quality the Radio Shack.
My 2 cents worth...
My 2 cents worth...
Criterion receivers (I, III, V, VII) were only around for the last catalog before Lafayette filed for bankruptcy. We did not receive any unique service related parts for these receivers. Personally, the LR-5555/5555A were much much better receivers. The 5555/5555A's also used the Sanken S-60W output power modules rather then discrete sets of transistors. The flywheel tuning on the LR-3030, 5555,9090 series receivers was fantastic. BUT, they all used the ALPS AC switch which was one of their most common failures.
This was my Parents first stereo which has been sitting in an upstate cabin in the elements for 45 years and still works.
Agreed on the flywheel tuning on the LR series. The LR-5555A uses the higher rated Sanken S-W80 output power modules. I do recall my old Criterion Mark iii did start to have the Alps power switch issues before I sold the receiver. In any case my personal thoughts Lafayette had the better bang for the buck then Radio Shack!
