C6Bill
You might find these screws easier to work with
https://www.sound-smith.com/accessories/ez-mount-cartridge-screws
I've used your method many times. Very simple, and thank you.
The bitch of it is, I'm always second-guessing. It isn't like some confetti shoots out of a cannon, announcing, "Hey, you got it correct!!"
Usually, I futz with it until I get frustrated, and then just go with what I have. I always seem to hit both null points on my mirrored thing I bought of e-prey.
I think the other bitch of it is, there's not really a right/wrong, within reason. Hence so many different ways to do it. Me, I DESPISE IGD. Kills the mood. Anyone know the best way to avoid IGD in regard to the alignment method?? (Baerwald, Stevenson, Stravinsky, Popeye?) p.s. two of those are fake, as if....![]()
Everyone mentioning to hold the nuts must be blind lol. Can't you see in the pic he needs spacers? The screws are TOO LONG and running out of threads before tightening down on the cartridge, simple as 1, 2, 3 lol.
No wonder so many find installing a cartridge difficult ROFLMAO.
Anyone thinking it's difficult installing a cartridge on a removable headshell should try it with one that's fixed, then you're really having fun lol.
Stevenson is the one with the second null point nearest the end of the record, and best for IGD. Most Japanese S-arms are made for a Stevenson alignment.Me, I DESPISE IGD. Kills the mood. Anyone know the best way to avoid IGD in regard to the alignment method?? (Baerwald, Stevenson, Stravinsky, Popeye?) p.s. two of those are fake, as if....
I've long despised cartridge alignment. Finally bought the gauge for my Thorens and its now minutes of effort that works vs many minutes of annoyance. Most of my other machines have no ability to align carts, which I like just fine but of the two that do, I have gauges for both now.
don't read too much into this, but you have to hold the nuts. Tweezers work, but you can probably just wedge a screwdriver between the nut and the cartridge body to get the same thing done. Or if you've got a set of ignition wrenches for adjusting points, possibly one is small enough.
I use fiber washers. As soon the nut get tight a little, stop it to spin allowing to tight from the screw only.
AG.
I tried to void metals, but the screws. Aluminum is my favor.Fiber on the nut and stainless or brass on the head end? Good idea.
It puzzles me that some have such difficulty with cartridge alignment. The first time I used a stylus protractor was when I bought a DB Systems Protractor in the early 1980's. It took me roughly half an hour that first time. Nowadays it takes less than ten minutes. It takes me longer to mount and connect the cartridge (Rega arm).
Best directions I've ever seen for using a two point protractor. Thanks to Ralph124c41 on Vinylengine.
With a 2-point protractor, set the stylus on the crosshairs of the outer grid, and square the cartridge to it.
Move to the inner grid, stylus on crosshairs.
If the cartridge angles toward the middle of the record, move it forward a bit, and start over.
If the cartridge angles away from the middle of the record, move it back a bit, and start over.
When the cartridge sits squarely in both grids, stylus on crosshairs, you are done.
When you have used a protractor, do not then try to adjust the cartridge to any other "overhang."
On a typical Technics type headshell, or a Dual sled, with a cart shaped like a classic Shure or similar, I find I can just hold the nut with my left index finger while I gently tighten the screw. Washers under the screw heads do make a world of difference about the cart not cocking when you snug them up however.
I too use the overhang gauges; I haven't noticed any issues. I suppose I *should* check with a protractor, but I just put away the Kennedy chest with all that stuff in it. (we're doing Christmas late this year; today is final cleaning and kids start showing up tomorrow.) I just bought a repro sled and two 12xx gauges from Best Audio by the way, and I would recommend them. The Pat's 101x sled that I bought ages ago when they were the only game in town works, but doesn't have the slots for the gauge, whereas the BA sleds are injection molded (not 3D printed) and look more original, and have both the groove to help you cue up on the front and also the 101x version has slots for the gauge. (I am going off their pictures, I did not buy the 101x version as I have several originals that I should repair "someday")
As for washers they should be M2.5 or #3 (about the same size) but typical M2.5 or #3 specs are larger OD than the ones that come with turntable hardware kits. I was OCD style searching because I wanted to get some more washers to use as spacers on XA headshells and found these (posted earlier in another thread) I think they're mil-spec #3 washers actually as I found these products which appear perfect.
https://www.mcmaster.com/90945A707
https://www.mcmaster.com/90945A708
https://www.amazon.com/gp/product/B07G4C9WZP (if you have Prime this is probably better than paying McMaster shipping costs, much as I love McMaster)
M2.5 screw OD = 2.5mm obviously (=0.0984")
#3-48 screw OD = .0990" = 2.5146mm
so they're basically interchangeable other than thread pitch which is something to be cognizant of when using headshells with fixed threads and not nuts...
A M2.5 washer will fit on a 3-48 machine screw; I tried. I measured the ones that come with the cartridge mounting screw kits at .190" with my HF calipers and the Mil-Spec #3s are nominal .180". This is why I think those are likely the washers included with the cartridge hardware kits. So I will probably order some after the holidays and neaten up my XA cart install. (I only have one original XA hardware kit but I found in my junk box a box of 3-48x1/2" SS fillister head screws and 3-48 SS nuts that I apparently bought from McMaster ages ago but for whatever reason I don't have any washers.)
Absolute genius.
