releone71
Many thanks for keeping in mind the P/L parts I was looking for. Unfortunately the faceplate from model 400 series II won't fit :-(...
Glad you have acquired the new 700B Toy. I bet you are already planning some restoration works. Have a great time then! I am traveling for two more weeks, so rarely coming back to the posts...
Hi P.L.F., you're the welcome!!.
Regarding the 700B, every part in the amp is 100% original, except the power cord. I cleaned the inside from dust and the pots with deoxit but I can still smell that bad smell. I can see also a thin grey film over the PCB and the white Sangamo caps, not so sticky though. I'm now aware that bad smell is not from the smokey environment of a disco, it's like the amp was rather used near the domestic fireplace. It's the typical smell of burnt wood. I've played several CDs yesterday from afternoon till evening and the amp worked perfectly.
I checked the offset across each output terminal and I read a tension of 10.5mV which gradually raises after half an hour to 15.5mV in the left channel and 0.5mV(?!) in the right channel. According to the 700 II manual, the correct value is 10.0mV, but is it valid for the 700B too? Even if I can say the amp stayed relatively cold while playing music yesterday afternoon (about 3 hours), do I have to change the offset setting? Or I'll better let things as they are untill they work? Could it be the difference in the readings between the channels an issue due to the old trimmers on the PCB? In any case the service manual and any other useful advice would be appreciated. Thanks!!
