The tangerine S55E is basically the same stylus as beej's purple S500ID, except for the boron-vapored cantilever. They were both "voiced" for a low-inductance (~350mH) body, so in the OP4 they should both sound a smidge rolled off on the tippy-top end-- which you may or may not notice, depending on your speakers, hearing acuity, mood, suggestibility, relative humidity, proximity to moon rocks, etc etc etc.
For the purposes of beej's test, this doesn't matter-- we only want to know if the UFR body contains some of that audiophile stuffing. If it doesn't, then you could buy a UFR stylus for your OP4 and enjoy the ride. If it does, the UFR becomes a unique body (like the 2000Z/T) which can only use its own dedicated stylus (if flat response is important to you).
beej, your 620x looks like a standard 350mH midline body that takes 239-D? styli. Measure it and let us know. You're not stuck using conicals, I know that.
Perhaps I'm misunderstanding your post here, but are you saying that the S55E (OE in my OP5) is intentionally voiced to be rolled off on the top end? I can say that is not the case at all with my OP5. :scratch2:
