Well, it's got all the right stuff... set up with separate inputs for MM and MC, and you can select the cartridge loading on MM (three settings each for resistance and capacitance).
S/N is speced at 80dB on MM and 74dB on MC, but I've found some examples to be a little noisy. Usually a good idea to use shorting plugs on the unused input, and also to go through the internal DC offset and other alignment settings for the various circuits, which does include the phono inputs. This is a case where the later production versions of this same basic design (3002 => 3002A => 3008A) improved over time, in terms of the components used (better caps, etc.) & in circuit design.
I don't know the other pieces you're comparing it to, sorry.
John
