ken kantor
Fowl Humor
Lots of obvious ones:
- Overly complex cabinet shape for no apparent benefit,
- With the largest driver here being 6" (guessing), it should be a 2-way - needless complexity, especially if it has a proper crossover network,
- Mid and tweeter domes look good together, but based on size, poorly chosen as their ranges likely very much overlap more than supplement each other,
- Midrange/tweeter plate looks like a single plate with two drive units - order of magnitude more difficult to manufacture plates with both drivers in spec; and far more difficult to find two decently matching mid/tweeter sets to assemble a matched pair of speakers,
- Top mounting the woofer directs most of its output very far off axis from the midrange/tweeter pair,
- Midrange/tweeter pair look to be spaced too far apart, (lobing? comb filtering? I forgot the big reason you try to minimize their distance)
- Uhhhhh... backplate with binding posts looks needlessly oversized. More expensive than the chunk of wood that was cut out, and probably more resonant / less damped than the wood that was there.
What else do people notice?
I too am thinking it's meant as a demo for manufacturing capability and detail. It's one thing to try break all the rules and "do something different", but other than the cabinet work, there's no clue that much thought was put into it.
As with everything, speaker building included, there's a pretty good reason that conventional designs are so common.
This is an >excellent< list. You know your speaker stuff! You listed some I hadn't particularly thought of. And I might add:
- Larger baffle area around woofer; smaller around MR and HR.
- Reverse positions of MR and HR to minimize combing with woofer.
- Using a single faceplate makes repair a pain in the butt. Note that the Phase Tech wisely uses separate FP's.
Now we can watch people here gotcha-attack our list point by point like a bunch of high-priced defense attorneys, while missing the forest for the trees. (Which is why I didn't want to post such in the first place.
-k
