Wow, good research!!!:thmbsp:
A&B Sound also had a very large record department at that store.![]()
Japanese. One of the several brands which applied to CEC to manufacture their products.Was Taya a Canadian brand that sold CEC products...
I really miss A&B Sound. I didn't buy lps there, but many a paycheck took a beating with cd purchases.
Was Taya a Canadian brand that sold CEC products, kinda like a Noresco/Dual thing?
No, I think Taya was kinda sub brand from Toshiba but sold everywhere around the world, sometimes as Marlux in some countries. Well...I'm Italian, as you can see, and found my Taya locally...What I meant was, was "Taya" a name that was used only(or mostly) in Canada? I used Noresco as a comparison, Dual turntables were German made, but sold by Noresco in Canada. It seems when Taya is mention here, it is mostly Canadians that respond.
Taya/Marlux TTs were manufactured by CEC as well as Realistic, Sanyo, Scott and even Marantz.
REFURBISHED TAYA LP - 100, made by Toshiba Audio Industral in 1976, 2 speed w/ Full WOOD Plinth, Belt drive Manual with no gimmics ! Stylus condition is Excellent condition(see below tracking). All in excellent condition - sounds stunning ! Dampened tone arm lift mechanism.
The rubber mat is in excellent condition. Minor marks on the dust cover - per picture. Note below that this t/t(needle) is able to play/track at 1 gram cartridge adjustment - sounds stunning ! .
NOTE : I've added 2 screws in order to clamp down the motor while in transport. It'll come with the belt on the plater & you'll have to remove it, remove these screws(I'll mark them), install the plater & then the belt; Then you're ready to roll !
REFURBISHING : Installed new Belt, oiled motor, adjusted Mechanism weight. Adjusted for zero balance & set for 1gm weight. I've supplied RCA output cables - ground was there. ALL cleaning Inside & Outside.
, what does that mean?Stylus condition is Excellent
Well this is not good. The spindle was completely frozen with dried-up lube. Looks like someone continued to play it with the frozen spindle. I have it cleaned up and turning wonderfully now but the platter hole is distorted so the platter rocks and wobbles horribly. Probably the death-wobble for this one!
