AR-3a Restoration
GD70
Lunatic Member
Mike from HVHiFi contacted me regarding a gent who needed his AR's worked on, so I took them on.
Serial numbers 71894 & 72111. Dates are Feb 6,1973 on the mid, Jan 22, 1973.
Basically they were in decent shape, with one top rear corner bashed, and one small spot on a bottom. The surrounds were shot. There were also some 15ohm L-pads installed. The original woofer had been coated with something, I'm guessing in an attempt to preserve the cracking surround. Someone had been in the other speaker back in 1982 or so. One woofer was replaced with a service replacement which would have been used in the series 9's according to Roy C. I decided to pull them and replace them with original pots, which Roy sent me in perfect condition. Otherwise I would have had to add a 25 ohm resistor parallel on the mid range L-pads to equal the other untouched speaker. The pots were in the other speaker were in near perfect condition! The caps were Spragues and the block 6uf cap. I replaced the Spragues with Benic npe's, 150 & 50uf and used a poly 6uf for the tweeter. The surrounds came from Simply Speakers. They have the correct surround for the 3a woofer with the 5/8ths dia. roll.
Caps and replacement pots have been installed, cabs were sanded, and veneer repairs completed, and I'm on the 5th application of Watco's. Here's some pics. Theoriginal grills are pretty good and I'm leaving them as is.
Here's some pics. Another fun project.
Glenn
Thanks gents!
The veneer is from my KLH Sixs that needed a complete reveneer. I was able to save some decent pieces of the original veneer when stripping them. You need old veneer for good splicing.
Glenn
Wow, nice work! You are a wizard with the veneer. I've got some screw holes to fill, but they are in the middle of the sides, any ideas?
Those are beautiful!
Paul
Great work as usual Glenn, I love seeing these gems of audio history being brought back to their glory! :thumbsup:
Great Job on the Cabs. Had dejavu looking at that one smashed corner, luckily you only had one, those are nice pots to work with there too
Paul
Hey Paul!
This is the one type of repair where I would use some putty, and some walnut sandng dust mixed in to help match the veneer color. Then some touch up with a stain, or walnut colored oil applied with a fine tip hobby paint brush.
Glenn
Thanks Steve!
These have an interesting history. They came from a retired Pianist from Julliard.
There was also an large enclosure single Altec for the room corner and a Marantz mono tube amp that was hooked up to the Altec. I didn't see those pieces though.
Thanks Steve!
I haven't fully finished my pair yet, the original controls are still problematic after sitting. When I fiddle with them and get them making contact, they still blow me away with their sound.
Looking at the post times and dates, that's a whole lot to accomplish in one day! You're the restoration Usain Bolt of AK!! :thumbsup:
Beautiful work.
Impressive work there, Glen! Do we have a new small business in the making?
GeeDeeEmm
Thanks GeeDee!
I've done 6-7 commissions now, and the extra cash is great because it gets blown pretty quickly on more audio toys for upgrades, or repairs for other gear I don't have the knowledge to do! Just spreading the wealth!
I wouldn't mind a couple of these a month, I really enjoy the process, I'm in the cave, so I get to hear my systems and tunes, and the best part is bringing these old beauties back to their former glory! Love it!
Glenn
