The Linn Basik LVX Musings - part 3: The Bearing Blues.
So this was quite a hiatus... Lots of other stuff (fixed voltage regulator on the old FJ43!), and lots and lots of noodling and failing.
We left our tonearm disassembled, with me having a list of things to polish, lost bearing balls, and a desire to upgrade them.
I also made quite a few mistakes in the Linn Part 2 Musings, which I intend to correct here.
Let's start with the bearing diagram...
This is sideways, with the bottom being on the right side of the picture. Not to scale!
Somewhere in the Part 2, I believe in one of the videos, I said that the perfect straightness of the brass tube (red piece on the diagram) is not that important. Well, that was mistake number one: it is! It's obvious from the diagram. Each bearing race is made out of three surfaces: a flat on the yoke or the tension nut, the tapers on the end of the fixed cylinder, and the brass tube itself.
Mistake number two, by the way, was the ball size. Ordered some "slightly bigger" (0.5mm balls - I measured approx. 0.4mm). They came, and I immediately realized they were too small. What the...?
I measured the originals as 0.014. The actual diameter of the originals was 0.039. Which happens to be 1mm!! Now that's a round number and makes a ton more sense. Those of you who ever used a micrometer should be laughing at me at this point
(hint: 0.039 - 0.014 = .025). Yeah. Dumba$$.
Well, 1mm bearing balls is a lot easier to find. I ultimately had a choice - stainless steel balls of pretty low grade (G25 if I recall right) from McMaster-Carr (whom I can trust), ceramic balls from VXB Bearings with no grade listed, or ceramic balls listed as G5 (a very nice grade!) from skiffmadeblades.com (seems like a knife shop). I decided to go with Skiff.
Meanwhile, once I realized the brass tube was integral to concentricity and everything, I decided to machine it in situ along with the yoke side race. That would make them perfectly concentric and perpendicular. Yes, my lathe is clapped out and cuts tapers (meaning that OD of the brass tube will be smaller by a few thousandths on one side than the other); but that's no problem here: ball's contact area is a point, so as long as we're all concentric and square, we should be fine.
That lead me to trying to make a jig, re-measuring, finding problems, measuring again, realizing that the most important part in the concentricity equation is the relationship of the "ears" of the yoke to the pivot.
It's much easier to explain when showing, so here:
And a bit of the results of the final straightening:
Did I say I wasn't gonna machine it?
Well, I did in the end.
... using my "puck with the screw" I described in part 2 and was so afraid would cause issues. It didn't.
One of the reasons I ended up deciding to machine was to get rid of the "divots" and pits on the flat race on the yoke, and start fresh.
Oh - I didn't mention the divots?
This is what we're dealing with guys. Those little "holes" dug by the balls over time is what is causing the rumbling noise when the thing spins; each ball has to roll "in" and "out" of the hole. How do I know?
Well... we'll get there. Let's say I staged an experiment to convince me.
I took off just a hair - just a couple thousandths - to make a clean new surface, and went to polishing.
Shoulder polishing, and ID polishing of the "fixed cylinder"'s race areas (remember the diagram?) took a lot of figuring out. What I learned is you can't skimp and rush, you have to have really good and thorough contact of your sandpaper to the surface and to be able to move the paper around. Make sure the paper is working (you should see the "slurry" of tiny chips and lubricant formed). Make sure to perfectly clean everything in between grits. Make sure grits don't touch each other (cross-contamination otherwise possible where you pick up coarser grit while doing a finer one). It's really hard to do in the corner!
For example, getting rid of marks I circled above proved to be damn night impossible. The rest of the "scratches" are really just my greasy fingersmudges
Well, okay; with yoke polished, and the fixed cylinder polished, and bearing balls here, it's assembly time.
First, we drown the balls in silicone oil (I decided to use 100 cst here).
Then, caaarefully position them around the yoke. Don't sneeze! Don't breathe, in fact.
Then, the fixed cylinder, and same thing there:
And then, all that remains is the nut, locknut, and adjust for freedom and zero play.
Initially, I put the nuts on with no loctite - in case I'd need to take it apart again. Let's check that noise, shall we?
Well, this is quite underwhelming.... I expected the rumble to go away, but it didn't.... Could it be balls hitting each other (there's no ball separator inside)? What else.... I don't know...
On the other hand, the cylinder itself (the thing I'm spinning) is out of balance (due to that flat cut-out in it); that may be one of the reasons?
This is not a high-speed assembly; if the balls are hitting each other that would cause some of the rumble you hear; but in practice the arm is rotating oh so slowly this isn't a factor?..
And then again, holding the cylinder and gently blowing on the yoke caused it to move - gently, with no hesitation and no "jageddness".
Damn; I wish I could chat with one of them tonearm mechanics
Tell you what. I'll take it.
What was left was to take the nuts back off, and put them on with Loctite with final adjustments........
... at which point Loctite threw me off, because it cured under the lock nut faster than I expected
.. which made me think it was tight when I was checking the bearing
... which it wasn't, which meant that final tightening caused the main nut to be pushed down...
... which I should've stopped at, because I should've stopped and questioned myself: hey, why is the lock nut wanting to go for another full turn??..
... but I didn't and just tightened it...
.... which did push the main nut down, and promptly locked up the bearing...
I loosened it, and immediately found the sound to have changed - completely. Now I know! I was sure I dug the new "divots" by over-tightening it... which changed the sound... which means that I did something _good_ with all the polishing and machining... only to promptly screw it up.
Hoping for I don't know what, disassembled it.
Yep. I made new divots....
.... but hey. Maybe that was Universe's way of showing me the ball contact area. Which was exactly the area where some machine marks were still present (most of what seems like "scratches" are again smudges of goop). Maybe re-doing this and trying to get as deep into that corner as humanly possible will improve this further...
Maybe this was Universe's way of convincing me that divots do make that rumbling noise, and polishing them out improves things by a mile (the noise went really, really downhill after my overtightening and loosening it).
And hence, the Bearings Blues.
We'll see.
We'll see.
