I have had this Rega RB 300 tonearm on a crappy custom TT I made out of MDF , plywood and a rack system Kenwood TT guts with a wimpy platter. It served me well for a while before I really got into TT's. I also Had an AR XA but never really gave it much of a chance as it needed a lot of work.
One day I decided to set up the AR and searched for info on it, I came to VinylNirvana where I saw so many cool AR builds and parts etc. I new I had to use the RB-300 on one some time in the future. But after more research I found AK and Marc Morins work on these old simple design tables. I realized the original arm is quite excellent once you add jewel bearings polish the pivot pins add a SME style collet/bayonet and some other little tweets to it.
So I began looking for more of these to work on just for fun. But I own a restaurant and
people began to move onto other jobs and I never could find any good quality cooks with common sense and who could handle the pressure of a mad rush with out having their hand held. So I worked more hours and had no time for these projects.
A few months ago before Wuhan reeked havoc on us, I found a cheap AR XA with no tone arm, I had extras here so I went to buy it. Well Once I got it home I realized it was cut for an SME 3009 series II arm.
So my plan was halted there.
Sub chassis pic with the cut out for the SME.
So I always loved the look of dual arm TT's and have been playing around in my head about a
dual arm AR XA TT, but my original plan was with two AR arms as I think they are great for their simplicity.
This fantasy has been with me for at least a decade. So now that I got this hacked sub chassis and
time from the shut down and I finished other more important projects around the house I decided last night to
go for it and chop up some TT's and try to figure out a Dual Arm AR XA Turntable!!!
So I first cut off a section of the hacked sub chassis to kinda play around with ideas.
I also cut off the side supports so when I affix it to the main chassis it wont be too
high and hit the top plate, I decided to use the underside face up.
I eventually also had to cut the small raised support section( still in pic above) to fit a wood mounting plate that will eventually go there. Another hole will be drilled overlapping the larger hole above, and the suspension stuff hole will line up with the main chassis's.
I had to remove some of the main chassis raised edges so the wider new arm board section will fit to it.
A quick mock up ......
I photo copied the original RB 300 arm template so I wouldn't ruin it, did the same on its original TT it was on.
I lined it up to see where I stand on new arm mount length . I can take some off the end later as I have room.
I drilled and tapped 4 screw holes to affix the new sub chassis section to the main one.
I still haven't drilled the overlapped hole in this pic. I forgot to take a pic of that, I will later.
Here is the pic of the overlapped hole I drilled out.
Here is a mock up with the two arms . I'll need to figure out the arm board height . I may make some
brass spacers. Still thinking on what would be best. Heavy or lighter, it depends on the spring compression
once I get a set of the heavier duty springs and try it out as is.
Then I need to figure out the plinth. If I sat and thought it out more I would have put the new extension on the front chassis wing so I could put the RB-300 on the right side of the TT and the AR arm would be in the back.
then the dimensions of the table would look better with a full length of wood on the right
for the added extension arm board, so to say . Now It will have a wide wood arm board along the back of the Table. This will make it probably close to square in shape. Unless I decide to add a wider body all around, that would make a very big foot print not common with these little XA's .
So what do you guys think?
Any other Ideas ?
Not sure how much more time I'll have for this as were getting close to re opening
soon....I hope
Athanasios
Any other Ideas ?
soon....I hope
Athanasios
